DDNS Updater DDNS Updater for OVH Provider not working anymore ?
fa355115
29. Jan. 2012
Hi there,
I am using 2 providers with DDNS Updater : Dyndns and OVH.
Dyndns is wtill working, but OVH is not working anymore.
In the past, I think I tested "ovh.com" as provider which you added recently upon my request, and I think it was working fine.
Recently, I saw I had in fact "Custom provider" using protocol "dyndns2" defined to have this provider working, so I deleted it to use the correct "www.ovh.com" as provider, but All I get is a "No response from Server" message, and the adress is not updated.
Here is the onformation I am filling in :
Provider: www.ovh.com
Protocol: ovh
Server: www.ovh.com
Hostname: xxx.be (Which is my domain)
IP:
Wildcard: nothing
Static: nothing
Custom: nothing
Login: <My login to OVH manager>
Password: <My password to OVH manager>
Confirm Password:
MX Hostname:
MX Priority: 1-999
Backup MX: nothing
... but All I get is a "No response from Server" message
Here is the log I get :
Jul 16 21:53:22 ddclient[545]: FAILED:    )
Jul 16 21:53:22 ddclient[545]: FAILED:    </body></html>
Jul 16 21:53:22 ddclient[545]: FAILED:    <address>Apache/2.2.20 (Unix) mod_ssl/2.2.20 OpenSSL/0.9.8g mod-xslt/1.3.9 Server at www.ovh.com Port 80</address>
Jul 16 21:53:22 ddclient[545]: FAILED:    <hr>
Jul 16 21:53:22 ddclient[545]: FAILED:    the credentials required.</p>
Jul 16 21:53:22 ddclient[545]: FAILED:    browser doesn't understand how to supply
Jul 16 21:53:22 ddclient[545]: FAILED:    credentials (e.g., bad password), or your
Jul 16 21:53:22 ddclient[545]: FAILED:    requested.  Either you supplied the wrong
Jul 16 21:53:22 ddclient[545]: FAILED:    are authorized to access the document
Jul 16 21:53:22 ddclient[545]: FAILED:    <p>This server could not verify that you
Jul 16 21:53:22 ddclient[545]: FAILED:    <h1>Authorization Required</h1>
Jul 16 21:53:22 ddclient[545]: FAILED:    </head><body>
Jul 16 21:53:22 ddclient[545]: FAILED:    <title>401 Authorization Required</title>
Jul 16 21:53:22 ddclient[545]: FAILED:    <html><head>
Jul 16 21:53:22 ddclient[545]: FAILED:    <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
Jul 16 21:53:22 ddclient[545]: FAILED:    Content-Type: text/html; charset=iso-8859-1
Jul 16 21:53:22 ddclient[545]: FAILED:    Connection: close
Jul 16 21:53:22 ddclient[545]: FAILED:    Content-Length: 521
Jul 16 21:53:22 ddclient[545]: FAILED:    Vary: Accept-Encoding
Jul 16 21:53:22 ddclient[545]: FAILED:    WWW-Authenticate: Basic realm="What is your nic handle and password ??"
Jul 16 21:53:22 ddclient[545]: FAILED:    Server: Apache/2.2.20 (Unix) mod_ssl/2.2.20 OpenSSL/0.9.8g mod-xslt/1.3.9
Jul 16 21:53:22 ddclient[545]: FAILED:    Date: Mon, 16 Jul 2012 19:53:23 GMT
Jul 16 21:53:22 ddclient[545]: FAILED:    Set-Cookie: slb=R3935405676; path=/; expires=Thu, 19-Jul-2012 08:11:47 GMT
Jul 16 21:53:22 ddclient[545]: FAILED:   updating xxx.be: authorization failed (HTTP/1.1 401 Authorization Required
... what is strange is that If I select "Custom provider" with protocol dyndns2, it is also not working.
Please note that I am sure about my Login and password (It is the one I use to connect to OVH manager, and it is working).
ok ... I have foud what the issue is, and I think ddns updater mught need some clarification.
In OVH, we can use 3 different things to connect as "Login" :
- NIC Handle
- Domain
- mail
... none of them are working if used in the "Login" field of DDns Updater.
What needs to be used is what OVH calls the "DynHost Identification".
Here it is working, and this is different from the 3 listed above.
i use the following url from the german site ovh.de
Update URL = http://www.ovh.com/nic/update?system=dyndns&hostname<domain>&myip<ipaddr>
 Domain Name = subdomain.IhreDomain
 Username = yourdomain-identifier
 Password = yourpassword
You can see the tag system=dyndns, this indicate that you want to update like the dyndns scheme.
The authentication are provided through Basic Auth, so the username and password are not part of the url.
On the french site i don't found this information.
