DDNS Updater DDNS Updater for GratisDNS.dk provider
Frederik
11. Dez. 2012
My German isn't that good, so I'll write in English. I hope that's OK.
I just bought a DS1512+, and I wanted to access the NAS through a domain instead of the IP-adress (I have a dynamical IP-address). Therefore I bought a domain at www.gratisdns.dk, which is also a DNS provider. Unfortunately I can't select the GratisDNS provider in the DSM.
Is it possible to add the GratisDNS provider with DDNS Updater? Or can I fix this issue another way?
I have this information about the provider:
https://ssl.gratisdns.dk/ddns.phtml?u=<username>&p=<password>&d=<domain>&h=<host>
Source of information:
http://forum.gratisdns.dk/wizard/DDNS/
http://forum.gratisdns.dk/gratisdns-nyheder/nu-med-dynamisk-dns-opdateringer-(weeeee!)/
I haven't configured DNS before, so I sincerely hope that you are able to help me solving this problem.
Best regards
Frederik
Yes, gratisdns.dk is not in the list of known providers and you can not use another provider (i.e. dyndns) with gratisdns,dk. I will implement this in the next release.
Hi QTip,
Thank you for your fast response!
I'm looking forward to the next release of DDNS Updater.
Do you know a approximated date of release?
Will new releases be announced in this thread: http://www.synology-forum.de/showthread.html?15723-Changelog? Or is there another "official" location where new releases will be announced?
Thank you in advance!
Best regards
Frederik
Hi QTip,
Best regards
Frederik
In aprox. 2 weeks. In your posted changelog thread or as package center notification. You can always look at http://www.cphub.net/ for new packages from our german community hub.
Thank you again!
I'm looking forward to the release.
- Frederik
Bitte wenn geht bald noch einen Provider hinzufügen.
Da mein Domainprovider mir den Dienst kostenlos als quasi Schmankerl anbietet, möchte ich bitten diesen auch noch zuzufügen.
Schade, dass man nur auf eine feste Liste zugreifen kann und nicht frei editieren kann.
Provider: Variomedia.de
Läuft, wenn ich es richtig verstanden habe, über securehost.de
Notwendige Daten dazu:
https://dyndns.securehost.de/
Oder hätte ich dafür neuen Beitrag aufmachen sollen?
Souli
Neuer Beitrag wäre besser gewesen, aber ok.
Das sieht nach dyndns2-Protocol aus, also kannst es per Custom Provider selbst anlegen.
Du legst mit "Hinzufügen" einen neuen "Custom Provider" an, wählst als Protokoll "dyndns2" und trägst als Serveradresse "dyndns.securehost.de" ein. Alle anderen Angaben wie Login und Passwort hast du ja.
Der Anbieter kann aber nur per SSL-Verbindung die Adresse aktualisieren, d.h. du must ipkg + perl + perl-IO-Socket-SSL installieren. Für ipkg gibt es hier schon genug Beiträge und auch im Wiki wirst du fündig, einfach mal danach suchen.
