DDNS Updater DDNS Updater 2 - Gratisdns.dk problem
Allan_84
06. Feb. 2017
hallo, ich habe DDNS Updater 2 2.1-169 auf DSM 5.2-5644 laufen.
ich versuche es zu funktionieren bekommen, aber leider hat es nicht geklappt.
LOG:
2017/02/06 10:51:22	CRITICAL : Could not get a valid ipv4 ip, update/check of [url]www.MYHOMEPAGE.dk[/url] will be aborted!
2017/02/06 10:51:22	WARNING : Use of uninitialized value in string ne at /var/packages/ddnsupdater2/target/sbin/ddud line 276.
2017/02/06 10:51:22	WARNING : Use of uninitialized value $ipt in string eq at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 221.
2017/02/06 10:51:22	WARNING : Use of uninitialized value $ipt in hash element at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 221.
2017/02/06 10:51:22	WARNING : Use of uninitialized value $ipt in string eq at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 213.
2017/02/06 10:51:22	WARNING : Use of uninitialized value $ipt in hash element at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 213.
2017/02/06 10:51:22	WARNING : Use of uninitialized value $ipt in hash element at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 198.
2017/02/06 10:51:22	WARNING : Use of uninitialized value $ipt in hash element at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 197.
2017/02/06 10:51:22	WARNING : Use of uninitialized value $ipt_ in concatenation (.) or string at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 197.
2017/02/06 10:51:22	WARNING : Use of uninitialized value $ipt_ in substitution (s///) at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 195.
2017/02/06 10:51:22	INFO : Debug mode: off
2017/02/06 10:51:22	WARNING : Use of uninitialized value in string eq at /var/packages/ddnsupdater2/target/sbin/ddud line 119.
2017/02/06 10:51:22	INFO : Daemon reloads config
2017/02/06 10:51:11	CRITICAL : Could not get a valid ipv4 ip, update/check of [url]www.MYHOMEPAGE.dk[/url] will be aborted!
2017/02/06 10:51:11	WARNING : Use of uninitialized value in string ne at /var/packages/ddnsupdater2/target/sbin/ddud line 276.
2017/02/06 10:51:11	WARNING : Use of uninitialized value $ipt in string eq at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 221.
2017/02/06 10:51:11	WARNING : Use of uninitialized value $ipt in hash element at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 221.
2017/02/06 10:51:11	WARNING : Use of uninitialized value $ipt in string eq at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 213.
2017/02/06 10:51:11	WARNING : Use of uninitialized value $ipt in hash element at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 213.
2017/02/06 10:51:11	WARNING : Use of uninitialized value $ipt in hash element at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 198.
2017/02/06 10:51:11	WARNING : Use of uninitialized value $ipt in hash element at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 197.
2017/02/06 10:51:11	WARNING : Use of uninitialized value $ipt_ in concatenation (.) or string at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 197.
2017/02/06 10:51:11	WARNING : Use of uninitialized value $ipt_ in substitution (s///) at /volume1/@appstore/ddnsupdater2/sbin/../lib/DDNSUpdater/Tools.pm line 195.
2017/02/06 10:51:10	INFO : Debug mode: off
2017/02/06 10:51:10	WARNING : Use of uninitialized value in string eq at /var/packages/ddnsupdater2/target/sbin/ddud line 119.
2017/02/06 10:51:10	INFO : Daemon reloads config
Obwohl aus dem Browser funktioniert es gut mit:
https://ssl.gratisdns.dk/ddns.phtml?u=USERNAME&p=PASSWORD&d=DOMAIN&h=HOST&i=IP
Habe Ich etwas übersehen?
Vielen Dank im Voraus
Bitte die Erstkonfiguration unter Einstellungen & Konfiguration durchführen, sollte normalerweise automatisch aufpoppen, wenn nicht erfolgt. Dort dann IP-Überprüfung und IP-System einstellen, anschließend sollte es funktionieren.
Vielen Dank, aber ich kann nirgendwo Erstkonfiguration finden.
Unter Einstellungen und Konfiguration habe ich geguckt, aber Ich kann mich nicht intuitiv erraten was hier zu einstellen, ich denke es is mit DDNS Updater 2 zu tun der nicht die ip von DSM intern bekomt, aber wie ich das mache weis ich nicht. ich habe auf die forum gesucht für eine anleitung, alles was ich gefunden habe, ist "Anleitung kommt demnächst... / Instructions coming soon ..."
hast du eine schrittweise anleitung oder?
Mit Erstkonfiguration sind diese beiden Konfigurationsoptionen "IP-Überprüfung und IP-System" (engl. IP check method and IP type) gemeint und genau diese beiden musst du bei der Erstinbetriebnahme einstellen.
Vielen Dank für die Hilfe, es war genau die Tipps, die ich brauchte, jetzt funktioniert es einfach.
Settings & Configuration
IP check method: Internal (DSM)
IP type: IPv4 only
