DDNS Updater DDNS Updater 1.26-002 and -003 "empty" after last Synology update
sanderl
11. Sep. 2010
Hello,
I have this problem that since the last Synology firmware update I do not have any config/information left in the DDNS updaterpane.
What can be the problem?
I have disabled cross-site forgery in security settings.
Have you tried to recreate new update configs? And which DSM version you are talking about?
Try to recereate new update configs? What is that? Do you mean to add my dns names all again? There were about 60!
I have DSM 4.3-3810 Udate 4. Latest thus.
Yes - just to test if it's a problem with the app itself. And it is not unusual that settings are lost or changed by a firmware update.
I don't dare. Afraid it overwrites all my previous config. How do I backup that?
I don't know exactly where the DDNS Updater saves the config. Maybe you should take a look (using telnet or ssh) into /volume1/@appstore/ , there should be a folder for the DDNS Updater. I assume there is a config file inside - but if this file isn't corrupted there is no reason why the domains are not visible in the app window.
You find the ddclient.conf in /var/packages/ddnsupdater/target/
Runs the DS 24h or did it shutdown every day? if 24h, then you can always look in /tmp/cache/ddclient, there is the running copy. Both files should be identical. if you have previously updated to 1.26-003 and the DS were not rebootet, then there is a good chance to have a backup of the previos DDNS updater in /volume1/@tmp
Always on... rebooted after dsm updates off course. I'll have a look tonight...
This is the 3rd time in ddns life time this happens. And it's A LOT of work to fill up alle domains again...
I have also seen the native ddns function of synology. Does that provide the same? Also with custom (svc.joker.com) ddns updates?
No, only the preconfigured services. But i assume it should be possible to edit/extend the preconfigured list (i saw such a remark somewhere here in the board).
It never happened to me, always the same config since over 4 years.
these 3 locations all give me a 1k file with no content... How the F### is that possible? It is allways a pain to upgrade my synology and get ddnsupdater working again... and now again... how is this uberhaupt possible?
/volume1/@tmp
/tmp/cache/ddclient
## ddclient.conf created 06/01/2014 17:14
daemon=300
max-interval=22d
ssl=no
syslog=yes
pid=/var/run/ddclient.pid
file=/tmp/cache/ddclient/ddclient.conf
cache=/tmp/cache/ddclient/ddclient.cache
#notify=@administrators
notify-failure=@administrators
#mail=root
#mail-failure=root
#offline-ip=46.38.245.163
#offline-script=
# DDNS Provider Parameters Section
Have you edited the config by yourself?
What do ypu mean qtip? I did not change anything other that the gui... i mean adding my ddns names by gui
Since so much duplicate entries are present, which can only be specified at post-upgrade script, i try to fix this. But this can not be the reason for the removal of your records.
Qtip, this was not the first time. I had this before.... and I am not alone. Previous updatrs of dsm more people had this. Rmember me asking few years ago for a "back-up" option :-)?
A backup/restore option and other new features are part of DDNS updater 2, but that can still take a while. I realize this is an important feature, and i'll include it in the next version.
I am afraid to put all names back in ddnsupdater again. I think it can be all lost again after next update...
And that sucks because ddnsupdater is a great addon on the synology! I would like a backup (copy config to a share) asap!
you can put all your records in and then make a backup of /var/packages/ddnsupdater/target/ddclient.conf, it is a regular text file.
Import and export are now available in version 1.27
