warte:
Ich möchte aus Datenschutzrechtlicen Gründen die die richtige Domain nicht posten daher habe ich das editiert. und die Domain ersetzt mit meine.domain.com
curl -v
https://meine.domain.com
* Trying 64:ff9b::50ab:33b4:443...
* Connected to meine.domain.com (64:ff9b::50ab:33b4) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/certs/ca-certificates.crt
* CApath: /etc/ssl/certs
* TLSv1.0 (OUT), TLS header, Certificate Status (22):
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN, server accepted to use h2
* Server certificate:
* subject: CN=meine.domain.com
* start date: Oct 28 20:08:29 2025 GMT
* expire date: Jan 26 20:08:28 2026 GMT
* subjectAltName: host "meine.domain.com" matched cert's "meine.domain.com"
* issuer: C=US; O=Let's Encrypt; CN=E8
* SSL certificate verify ok.
* Using HTTP2, server supports multiplexing
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x560676b689f0)
> GET / HTTP/2
> Host: meine.domain.com
> user-agent: curl/7.81.0
> accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* old SSL session ID is stale, removing
* Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
< HTTP/2 502
< server: nginx
< date: Mon, 10 Nov 2025 08:14:00 GMT
< content-type: text/html
< content-length: 11939
< etag: "659e3f7c-2ea3"
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<style>body{font-family:Arial,Helvetica,sans-serif;font-size:12px;text-align:center}h1{color:#06C;font-size:25px;line-height:60px;margin-top:56px}img{margin-top:40px}
</style>
</head>
<body>
<img ... />
<h1 id="a"></h1>
<hr>
<p>© 2024 <a href="
http://www.synology.com">Synology Inc.</a></p>
</body>
<script type ="text/javascript">
/* Copyright (c) 2024 Synology Inc. All rights reserved. */
(function(){var a={de:"Es tut uns Leid, die von Ihnen gesuchte Seite konnte nicht gefunden werden."};var b=window.navigator.language;if(-1==["zh-TW","zh-MO","zh-HK","pt-BR"].indexOf(b)){b=b.split("-",1)}document.getElementById("a").innerHTML=a
||a.en})();
</script>
</html>
* Connection #0 to host meine.domain.com left intact
