CloudSync Container haben ein seltsames Problem mit CloudSync.
bisky39
18. Jan. 2022
On my Synology, I run the Unifi controller and a Home Assistant server in Docker containers, but strangely, if I set the Unifi controller to back up its database once an hour and this volume, the files are not uploading properly watch with CloudSync . That means not at all.
I can also simulate this by going into this container's Docker terminal and using the Linux "touch" command to write new files, but CloudSync still won't notice that a file has been added to a directory that should monitor it.
This is a known limitation of Cloud Sync. Workaround: Create an automated task in the task scheduler that restarts the Cloud Sync service e.g. every 15 minutes. After the restart, Cloud Sync should sync these files correctly.
Thank you for your support.
