Autoindex und Google Adsense
rauppe31
06. Juni 2011
Hallo
Ich wollte gerade meinen Adsense Code in das AutoIndex-Script einbauen.
Aber irgendwie werden die Anzeigen nicht angezeigt.
Villeicht könnt ihr euch den Code mal anschauen.
index.php (Teil 1)
<?php
 * Handles all requests by the browser. This is the only file that can be
 * accessed directly.
 * @package AutoIndex
 * @author Justin Hagstrom <JustinHagstrom@yahoo.com>
 * @version 1.2.1 (January 06, 2007)
 * @copyright Copyright (C) 2002-2007 Justin Hagstrom
 * @license http://www.gnu.org/licenses/gpl.html GNU General Public License (GPL)
 * @link http://autoindex.sourceforge.net
   AutoIndex PHP Script is free software; you can redistribute it and/or modify
   it under the terms of the GNU General Public License as published by
   the Free Software Foundation; either version 2 of the License, or
   (at your option) any later version.
   AutoIndex PHP Script is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
   GNU General Public License for more details.
   You should have received a copy of the GNU General Public License
   along with this program; if not, write to the Free Software
   Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
 * OPTIONAL SETTINGS:
//filenames and paths for configuration related files
define('CONFIG_STORED', 'AutoIndex.conf.php');
define('CONFIG_GENERATOR', 'config.php');
//paths for files that will be included
define('PATH_TO_CLASSES', './classes/');
define('PATH_TO_LANGUAGES', './languages/');
define('LANGUAGE_FILE_EXT', '.txt');
//filenames of template files
define('GLOBAL_HEADER', 'global_header.tpl');
define('GLOBAL_FOOTER', 'global_footer.tpl');
define('TABLE_HEADER', 'table_header.tpl');
define('TABLE_FOOTER', 'table_footer.tpl');
define('EACH_FILE', 'each_file.tpl');
 * When ENABLE_CACHE is true, the indexes of directories will be stored in
 * files in the folder CACHE_STORAGE_DIR. You will notice a speed improvement
 * when viewing folders that contain a few thousand files. However, the contents
 * of the indexed folders will not be updated until you delete the cache file.
define('ENABLE_CACHE', false);
 * This is the folder cache data will be stored in. PHP needs write permission
 * in this directory. You can use an absolute path or a relative path, just
 * make sure there is a slash at the end.
define('CACHE_STORAGE_DIR', './cache/');
 * Format to display dates in.
 * @see date()
define('DATE_FORMAT', 'Y-M-d');
 * Sets debug mode. Off (false) by default.
define('DEBUG', false);
/* END OPTIONAL SETTINGS */
/** The time this script began to execute. */
define('START_TIME', microtime(true));
/** Level for disabled/banned accounts. */
define('BANNED', -1);
/** Level for Guest users (users who are not logged in). */
define('GUEST', 0);
/** Level for regular user accounts. */
define('USER', 1);
/** Level for moderator ("super user") accounts. */
define('MODERATOR', 2);
/** Level for Admin users. */
define('ADMIN', 3);
 * Minimum user level allowed to upload files.
 * Use the ADMIN, MODERATOR, USER, GUEST constants.
 * GUEST will allow non-logged-in users to upload.
define('LEVEL_TO_UPLOAD', USER);
/** The version of AutoIndex PHP Script (the whole release, not based on individual files). */
define('VERSION', '2.2.4');
 * This must be set to true for other included files to run. Setting it to
 * false could be used to temporarily disable the script.
define('IN_AUTOINDEX', true);
if (@get_magic_quotes_gpc())
//remove any slashes added by the "magic quotes" setting
	$_GET = array_map('stripslashes', $_GET);
	$_POST = array_map('stripslashes', $_POST);
@set_magic_quotes_runtime(0);
$_GET = array_change_key_case($_GET, CASE_LOWER);
$_POST = array_change_key_case($_POST, CASE_LOWER);
if (@ini_get('zlib.output_compression') == '1')
//compensate for compressed output set in php.ini
	header('Content-Encoding: gzip');
 * Uncomment the following code to turn on strict XHTML 1.1 compliance in
 * users' browsers. If you do this, make sure any changes you make to the
 * template do not break XHTML 1.1 compliance.
/*if (isset($_SERVER['HTTP_ACCEPT']) && preg_match('#application/(xhtml\+xml|\*)#i', $_SERVER['HTTP_ACCEPT']))
	header('Content-Type: application/xhtml+xml');
session_name('AutoIndex2');
session_start();
 * Formats $text within valid XHTML 1.1 tags and doctype.
 * @param string $text
 * @param string $title
 * @return string
function simple_display($text, $title = 'Error on Page')
	return '<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en">
<head>
	<title>' . $title . '</title>
	<style type="text/css" title="AutoIndex Default">
		html, body
			font-family: verdana, lucidia, sans-serif;
			font-size: 13px;
			background-color: #F0F0F0;
			color: #000000;
	</style>
</head>
<body>
<script type="text/javascript"><!--
google_ad_client = "ca-pub-0174021306594218";
/* Seite unten */
google_ad_slot = "2732606009";
google_ad_width = 336;
google_ad_height = 280;
</script>
src="http://pagead2.googlesyndication.com/pagead/show_ads.js">
</script>
<p>' . $text . '</p></body></html>
Powered by AutoIndex PHP Script (version ' . VERSION . ')
 * This function is automatically called by PHP when an undefined class is
 * called.
 * A file with the classname followed by .php is included to load the class.
 * The class should start with an upper-case letter with each new word also in
 * upper-case. The filename must match the class name (including case).
 * @param string $class The name of the undefined class
function __autoload($class)
	if ($class != 'self')
		$file = PATH_TO_CLASSES . $class . '.php';
		/** Try to load the class file. */
		if (!@include_once($file))
			die(simple_display('Error including file <em>'
			. htmlentities($file) . '</em> - cannot load class.'));
 * This is used to report a fatal error that we cannot display with the Display
 * class. All Exceptions used in AutoIndex should inherit from this class.
class ExceptionFatal extends Exception {}
try
	//now we need to include either the stored settings, or the config generator:
	if (@is_file(CONFIG_STORED))
		if (!@is_readable(CONFIG_STORED))
			throw new ExceptionFatal('Make sure PHP has permission to read the file <em>'
			. Url::html_output(CONFIG_STORED) . '</em>');
		$config = new ConfigData(CONFIG_STORED);
	else if (@is_file(CONFIG_GENERATOR))
		/** Include the config generator so a new config file can be created. */
		if (!@include_once(CONFIG_GENERATOR))
			throw new ExceptionFatal('Error including file <em>'
			. Url::html_output(CONFIG_GENERATOR) . '</em>');
		die();
	else
		throw new ExceptionFatal('Neither <em>'
		. Url::html_output(CONFIG_GENERATOR) . '</em> nor <em>'
		. Url::html_output(CONFIG_STORED) . '</em> could be found.');
	//find and store the user's IP address and hostname:
	$ip = (isset($_SERVER['REMOTE_ADDR']) ? $_SERVER['REMOTE_ADDR'] : 'N/A');
	if (isset($_SESSION['host']))
		$host = $_SESSION['host'];
	else
		$_SESSION['host'] = $host = @gethostbyaddr($ip);
	//Create a language object:
	$words = new Language();
	//Create a logging object:
	$log = new Logging($config -> __get('log_file'));
	foreach ($config as $key => $item)
	/* Go through each config setting, and set a constant with each setting's
	 * name to either true or false depending on if the config setting is
	 * enabled.
Danke.
index.php (Teil 2)
		$key = strtoupper($key);
		if (defined($key))
			throw new ExceptionFatal(Url::html_output($key)
			. ' is already defined in <em>' . basename(Url::html_output($_SERVER['PHP_SELF']))
			. '</em>, and should not be in the config file.');
		define($key, ($item != 'false' && $item != '0'));
	//make sure all required settings are set in the config file
	foreach (array('base_dir', 'icon_path', 'language', 'template',
		'log_file', 'description_file', 'user_list', 'download_count',
		'hidden_files', 'banned_list', 'show_dir_size', 'use_login_system',
		'force_download', 'search_enabled', 'anti_leech', 'entries_per_page',
		'must_login_to_download', 'archive', 'days_new', 'thumbnail_height',
		'bandwidth_limit', 'md5_show', 'parse_htaccess') as $set)
		if (!defined(strtoupper($set)))
			throw new ExceptionFatal('Required setting <em>' . $set
			. '</em> is not set in <em>' . Url::html_output(CONFIG_STORED)
			. '</em>');
	/* From this point on, we can throw ExceptionDisplay rather than
	 * Exception since all the configuration is done.
	$b_list = $only_these_ips = $banned_ips = array();
	if (BANNED_LIST && @is_file($config -> __get('banned_list')))
	//make sure the user is not banned
		$b_list = @file($config -> __get('banned_list'));
		if ($b_list === false)
			throw new ExceptionDisplay('Error reading from banned_list file.');
		for ($i = 0; $i < count($b_list); $i++)
			$b_list[$i] = rtrim($b_list[$i], "\r\n");
			if (ConfigData::line_is_comment($b_list[$i]))
				continue;
			if ($b_list[$i]{0} === ':')
				$only_these_ips[] = substr($b_list[$i], 1);
			else
				$banned_ips[] = $b_list[$i];
		if (count($only_these_ips) > 0)
			if (!(DirectoryList::match_in_array($ip, $only_these_ips) ||
				DirectoryList::match_in_array($host, $only_these_ips)))
				throw new ExceptionDisplay($words -> __get('the administrator has blocked your ip address or hostname') . '.');
		else if (DirectoryList::match_in_array($ip, $banned_ips) ||
			DirectoryList::match_in_array($host, $banned_ips))
	$show_only_these_files = $hidden_files = array();
	if (HIDDEN_FILES && @is_file($config -> __get('hidden_files')))
	//store the hidden file list in $hidden_list
		$hidden_list = @file($config -> __get('hidden_files'));
		if ($hidden_list === false)
			throw new ExceptionDisplay('Error reading from "hidden_files" file.');
		for ($i = 0; $i < count($hidden_list); $i++)
			$hidden_list[$i] = rtrim($hidden_list[$i], "\r\n");
			if (ConfigData::line_is_comment($hidden_list[$i]))
				continue;
			if ($hidden_list[$i]{0} === ':')
				$show_only_these_files[] = substr($hidden_list[$i], 1);
			else
				$hidden_files[] = $hidden_list[$i];
	//size of the "chunks" that are read at a time from the file (when $force_download is on)
	$speed = (BANDWIDTH_LIMIT ? $config -> __get('bandwidth_limit') : 8);
	if (DOWNLOAD_COUNT)
		if (!@is_file($config -> __get('download_count')))
			$h = @fopen($config -> __get('download_count'), 'wb');
			if ($h === false)
				throw new ExceptionDisplay('Could not open download count file for writing.'
				. ' Make sure PHP has write permission to this file.');
			fclose($h);
		$downloads = new ConfigData($config -> __get('download_count'));
	//create a user object:
	$log_login = false;
	if (USE_LOGIN_SYSTEM && isset($_POST['username'], $_POST['password'])
		&& $_POST['username'] != '' && $_POST['password'] != '')
		$you = new UserLoggedIn($_POST['username'], sha1($_POST['password']));
		$log_login = true;
		$_SESSION['password'] = sha1($_POST['password']);
		unset($_POST['password']);
		$_SESSION['username'] = $_POST['username'];
	else if (USE_LOGIN_SYSTEM && isset($_SESSION['username'], $_SESSION['password']))
		$you = new UserLoggedIn($_SESSION['username'], $_SESSION['password']);
	else
		$you = new User();
		if (MUST_LOGIN_TO_DOWNLOAD && USE_LOGIN_SYSTEM)
			$str = '<p>You must login to view and download files.</p>'
			. '<table border="0" cellpadding="8" cellspacing="0">'
			. '<tr class="paragraph"><td class="autoindex_td">'
			.  $you -> login_box() . '</td></tr></table>';
			echo new Display($str);
			die();
	//set the logged in user's home directory:
	$dir = Item::make_sure_slash((($you -> home_dir == '') ? $config -> __get('base_dir') : $you -> home_dir));
	$config -> set('base_dir', $dir);
	$subdir = '';
	if (isset($_GET['dir']))
		$dir .= Url::clean_input($_GET['dir']);
		$dir = Item::make_sure_slash($dir);
		if (!@is_dir($dir))
			header('HTTP/1.0 404 Not Found');
			$_GET['dir'] = ''; //so the "continue" link will work
			throw new ExceptionDisplay('The directory <em>'
			. Url::html_output($dir) . '</em> does not exist.');
		$subdir = substr($dir, strlen($config -> __get('base_dir')));
		if (isset($_GET['file']) && ($file = $_GET['file']))
			while (preg_match('#\\\\|/$#', $file))
			//remove all slashes from the end of the name
				$file = substr($file, 0, -1);
			$file = Url::clean_input($file);
			if (!@is_file($dir . $file))
				throw new ExceptionDisplay('The file <em>'
				. Url::html_output($file) . '</em> does not exist.');
			if (ANTI_LEECH && !isset($_SESSION['ref']) && (!isset($_SERVER['HTTP_REFERER'])
			|| stripos($_SERVER['HTTP_REFERER'], $_SERVER['SERVER_NAME']) === false))
				$log -> add_entry('Leech Attempt');
				$self = $_SERVER['SERVER_NAME'] . Url::html_output($_SERVER['PHP_SELF'])
				. '?dir=' . Url::translate_uri($subdir);
				throw new ExceptionDisplay('<h3>This PHP Script has an Anti-Leech feature turned on.</h3>'
				. ' <p>Make sure you are accessing this file directly from <a class="autoindex_a" href="http://'
				. $self . '">http://' . $self . '</a></p>');
			$log -> add_entry($file);
			if (DOWNLOAD_COUNT)
				$downloads -> add_one($dir . $file);
			$url = new Url($dir . $file, true);
			$url -> download();
	if ($log_login)
		$log -> add_entry('Successful login (Username: '
		. $_SESSION['username'] . ')');
	if (DESCRIPTION_FILE)
		$descriptions = new ConfigData((@is_file($config -> __get('description_file')))
			? $config -> __get('description_file') : false);
	if (PARSE_HTACCESS)
		//parse .htaccess file(s)
		new Htaccess($dir, '.htaccess');
	if (MD5_SHOW && isset($_GET['md5']) && $_GET['md5'] != '')
		$file = $dir . Url::clean_input($_GET['md5']);
		if (!@is_file($file))
			throw new ExceptionDisplay('Cannot calculate md5sum: the file <em>'
		$size = (int)@filesize($file);
		if ($size <= 0 || $size / 1048576 > $config -> __get('md5_show'))
			throw new ExceptionDisplay('Empty file, or file too big to calculate the'
			. 'md5sum of (according to the $md5_show variable).');
		die(simple_display(md5_file($file), 'md5sum of '
		. Url::html_output($file)));
	if (THUMBNAIL_HEIGHT && isset($_GET['thumbnail']))
Und noch Teil 3
		$fn = Url::clean_input($_GET['thumbnail']);
		if ($fn == '')
			die();
		echo new Image($fn);
	if (ARCHIVE && isset($_GET['archive']))
		$log -> add_entry('Directory archived');
		$outfile = Item::get_basename($subdir);
		if ($outfile == '' || $outfile == '.')
			$outfile = 'base_dir';
		$mime = new MimeType('.tar');
		header('Content-Type: ' . $mime -> __toString());
		header('Content-Disposition: attachment; filename="'
		. $outfile . '.tar"');
		@set_time_limit(0);
		$list = new DirectoryList($dir);
		$tar = new Tar($list, $outfile, strlen($dir));
		die();
	//set the sorting mode:
	if (isset($_GET['sort']) && $_GET['sort'] != '')
		$_SESSION['sort'] = $_GET['sort'];
	else if (!isset($_SESSION['sort']))
		$_SESSION['sort'] = 'filename'; //default sort mode
	//set the sorting order:
	if (isset($_GET['sort_mode']) && ($_GET['sort_mode'] == 'a' || $_GET['sort_mode'] == 'd'))
		$_SESSION['sort_mode'] = $_GET['sort_mode'];
	else if (!isset($_SESSION['sort_mode']))
		$_SESSION['sort_mode'] = 'a'; //default sort order
	if (count($_FILES) > 0)
	//deal with any request to upload files:
		$upload = new Upload($you); //the constructor checks if you have permission to upload
		$upload -> do_upload();
	if (USE_LOGIN_SYSTEM)
		if (isset($_GET['logout']) && $_GET['logout'] == 'true')
			$you -> logout();
		else if (isset($_GET['action']) && $_GET['action'] != '')
			$admin = new Admin($you); //the constructor checks if you really are an admin
			$admin -> action($_GET['action']);
	if (ANTI_LEECH && !isset($_SESSION['ref']))
		$_SESSION['ref'] = true;
	$search_log = '';
	if (SEARCH_ENABLED && isset($_GET['search'], $_GET['search_mode'])
		&& $_GET['search'] != '' && $_GET['search_mode'] != '')
		$s = Url::clean_input($_GET['search']);
		$dir_list = new Search($s, $dir, $_GET['search_mode']);
		$search_log = "Search: $s";
	else if (ENABLE_CACHE)
		$cache = CACHE_STORAGE_DIR . strtr($dir, '\/:', '---'); //path to cache file
		if (@is_file($cache))
			$contents = @file_get_contents($cache);
			if ($contents === false)
				throw new ExceptionDisplay('Cannot open cache file for reading. Make sure PHP has read permission for these files.');
			$dir_list = unserialize($contents);
		else
			$dir_list = new DirectoryListDetailed($dir);
			if (!@is_dir(CACHE_STORAGE_DIR))
				if (!Admin::mkdir_recursive(CACHE_STORAGE_DIR))
				//Attempt to create the directory. If it fails, tell the user to manually make the folder.
					throw new ExceptionDisplay('Please create the directory <em>'
					. Url::html_output(CACHE_STORAGE_DIR)
					. '</em> so cache files can be written.');
			$h = @fopen($cache, 'wb');
			if ($h === false)
				throw new ExceptionDisplay('Cannot write to cache file. Make sure PHP has write permission in the cache directory.');
			fwrite($h, serialize($dir_list));
			fclose($h);
	else
		$page = ((ENTRIES_PER_PAGE && isset($_GET['page'])) ? (int)$_GET['page'] : 1);
		$dir_list = new DirectoryListDetailed($dir, $page);
		$max_page = (ENTRIES_PER_PAGE ? (ceil($dir_list -> total_items() / $config -> __get('entries_per_page'))) : 1);
	$log -> add_entry($search_log);
	$str = $dir_list -> __toString();
catch (ExceptionDisplay $e)
	echo $e;
catch (Exception $e)
	echo simple_display($e -> getMessage());
das würde ich den Schreiberling des Codes fragen. Ausserdem könnte es von Vorteil sein, wenn du das Fehlerlogging von PHP auf der DS aktivieren würdest
Ist aktiviert.
Wo ist denn das Logfile?
Die Fehlerausgabe sollte direkt im Browser erfolgen. ggf musst du in der Quelltextansicht der Seite gucken. Ich schau mir sicher nicht den ganzen Code an, aber für mich scheint es dass es sich dabei nur um das Klassenfile handelt. Wo erfolgt denn bei dir der Objektaufruf? Oder hast du nur diesen Code in deinen Webspace geschoben und gehofft es würde von selber gehen? ;-)
was passiert denn wenn du obigen Code in ein php packst und dann im Browser direkt aufrufst? Einfach eine weisse Seite oder wird was ausgegeben?
Dann kommt: Error including file ./classes/Url.php - cannot load class.
Da hast du die Antwort :-) Der Pfad ist falsch :-)
Und was muss ich jetzt ändern?
mhm wie wärs damit die Files dort abzulegen wo sie auch erwartet werden?? ;-)
im Verzeichnis wo deine index.php liegt muss es ein Unterverzeichnis classes geben, welches die Files beinhalten muss
Das gibt es ja auch.
und dort drin ist die gesuchte Url.php??
Warum eine URL.php?
Wir reden doch hier vom Adsense Code, den ich in die index.php integrieren will.
Die Fehlermeldung kam, als ich nur die index.php ohne die ganzen Ordner in ein Verzeichnis kopiert und dann aufgerufen habe.
Mit den ganzen Ordnern funktioniert es natürlich, aber die Adsense Anzeige wird nicht angezeigt.
okay, dann haben wir ein wenig aneinander vorbeigeschrieben. Mit dem Testumfeld wollte ich nur sichergehen, dass es nicht doch ein PHP Fehler ist :-) Scheint aber nicht so zu sein. Wenn ich dich richtig verstanden habe, hast du einen eigenen AdSenseCode, den du eingebaut hast. Wo genau hast du ihn denn in den autoindex eingebaut? Und bitte sag nicht einfach "File 2", sondern such die relevanten Codezeilen raus und poste sie hier. Und pack bitte PHP Code jeweils auch in PHP-Tags des Forums. Die resultierende Einfärbung des Codes kann sehr hilfreich sein gewisse Arten der Fehler zu finden (machts auch angenehmer zu lesen)
Ich hänge die Datei mal an. Einfach das .txt entfernen.
Der Google Code ist in Zeile 171.
Ich hoffe, dass wir eine Lösung finden.
Anhang anzeigen index.php.txt
danke dass du mich ignorierst :-(
dann mach ich das ab jetzt auch
