- 01. Apr. 2008
habe über IPKG asterisk14 und asterisk14-gui installiert. Habe nach dem Handbuch die http.conf und manager.conf angepasst.
Wenn ich nun versuche die Conf-Seite über http://x.x.x.x:8088/asterisk/static/ajamdemo.html aufzurufen erhalte ich im Browser folgene Fehlermeldung: Sie haben nicht die erforderliche Berechtigung, um die Seite anzuzeigen.
Manager.conf:
[general]
displaysystemname = yes
enabled = no
webenabled = yes
port = 5038
;httptimeout = 60
; a) httptimeout sets the Max-Age of the http cookie
; b) httptimeout is the amount of time the webserver waits
; on a action=waitevent request (actually its httptimeout-10)
; c) httptimeout is also the amount of time the webserver keeps
; a http session alive after completing a successful action
bindaddr = 0.0.0.0
;displayconnects = yes
; Add a Unix epoch timestamp to events (not action responses)
;timestampevents = yes
;[mark]
secret = gooey
;deny=0.0.0.0/0.0.0.0
;permit=209.16.236.73/255.255.255.0
; If the device connected via this user accepts input slowly,
; the timeout for writes to it can be increased to keep it
; from being disconnected (value is in milliseconds)
; writetimeout = 100
; Authorization for various classes
;read = system,call,log,verbose,command,agent,user,config
;write = system,call,log,verbose,command,agent,user,config
http.conf:
[general]
; Whether HTTP interface is enabled or not. Default is no.
enabled=yes
; Whether Asterisk should serve static content from http-static
; Default is no.
;enablestatic=yes
; Address to bind to. Default is 0.0.0.0
bindaddr=0.0.0.0
; Port to bind to (default is 8088)
bindport=8088
; Prefix allows you to specify a prefix for all requests
; to the server. The default is "asterisk" so that all
; requests must begin with /asterisk
prefix=asterisk
; The post_mappings section maps URLs to real paths on the filesystem. If a
; POST is done from within an authenticated manager session to one of the
; configured POST mappings, then any files in the POST will be placed in the
; configured directory.
;[post_mappings]
; In this example, if the prefix option is set to "asterisk", then using the
; POST URL: /asterisk/uploads will put files in /opt/var/lib/asterisk/uploads/.
;uploads = /opt/var/lib/asterisk/uploads/
CS407 aktuelle FW
THX all
Manager.conf:
[general]
enabled = no
webenabled = yes
port = 5038
;httptimeout = 60
bindaddr = 0.0.0.0
;[mark]
secret = gooey
http.conf:
[general]
enabled=yes
; Default is no.
;enablestatic=yes
bindaddr=0.0.0.0
bindport=8088
prefix=asterisk
;[post_mappings]
CS407 aktuelle FW
THX all
- da wäre hier viele Leute (einschliesslich mir) sehr interessiert an einem How To oder Wiki Beitrag. Ich habe schon viel mit meinen Diskstations experimentiert, aber die Sache mit dem Phone wär für mich doch eher ein böhmisches Dorf.
