Environment variables loaded from .env
Prisma schema loaded from prisma/schema.prisma
✔ Generated Prisma Client (v5.3.1) to ./node_modules/@prisma/client in 791ms
Start using Prisma Client in Node.js (See:
https://pris.ly/d/client)
import { PrismaClient } from '@prisma/client'
const prisma = new PrismaClient()
or start using Prisma Client at the edge (See:
https://pris.ly/d/accelerate)
import { PrismaClient } from '@prisma/client/edge'
See other ways of importing Prisma Client:
http://pris.ly/d/importing-client
[collector] info: [TikTokenTokenizer] Initialized new TikTokenTokenizer instance.
[collector] info: Collector hot directory and tmp storage wiped!
[collector] info: Document processor app listening on port 8888
Datasource "db": SQLite database "anythingllm.db" at "file:../storage/anythingllm.db"
Error: Schema engine error:
SQLite database error
unable to open database file: ../storage/anythingllm.db
✔ Generated Prisma Client (v5.3.1) to ./node_modules/@prisma/client in 1.01s
✔ Generated Prisma Client (v5.3.1) to ./node_modules/@prisma/client in 876ms
33 migrations found in prisma/migrations
Error: SQLite database error
attempt to write a readonly database
0: sql_schema_connector::sql_migration_persistence::initialize
with namespaces=None
at schema-engine/connectors/sql-schema-connector/src/sql_migration_persistence.rs:14
1: schema_core::state::ApplyMigrations
at schema-engine/core/src/state.rs:201
