*blubb*
da lag wohl noch das Wlan- Kabel im Weg![]()
00:10:29.106305 SQPmp Request 222 on socket 10 queued for processing (1 items on Q)
00:10:29.106338 SQW04 Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:32.108702 SQPmp Request 223 on socket 10 queued for processing (1 items on Q)
00:10:32.108736 SQW02 Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:32.415384 SQPmp Request 224 on socket 12 queued for processing (1 items on Q)
00:10:32.415421 SQW03 Processing connection from IP=127.0.0.1 socket=12 (2 out of 4 threads idle)
00:10:32.471218 SQPmp Request 225 on socket 13 queued for processing (1 items on Q)
00:10:32.471254 SQW01 Processing connection from IP=127.0.0.1 socket=13 (1 out of 4 threads idle)
00:10:32.530360 SQPmp Request 226 on socket 12 queued for processing (1 items on Q)
00:10:32.530396 SQW03 Processing connection from IP=127.0.0.1 socket=12 (1 out of 4 threads idle)
00:10:33.109920 SQPmp Request 227 on socket 10 queued for processing (1 items on Q)
00:10:33.109950 SQW03 Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:33.115471 SQW03 API method name: IProgress::COMGETTER(ErrorInfo)
00:10:33.115494 SQW03 API return code: 0x80004005 (NS_ERROR_FAILURE)
00:10:33.115501 SQW03 COM error info result code: 0x80004005 (NS_ERROR_FAILURE)
00:10:33.115506 SQW03 COM error info text: Error info is not available, operation is still in progress
00:10:33.133157 SQPmp Request 228 on socket 10 queued for processing (1 items on Q)
00:10:33.133188 SQW03 Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:35.120830 SQPmp Request 229 on socket 10 queued for processing (1 items on Q)
00:10:35.120861 SQW01 Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:35.171508 SQPmp Request 230 on socket 10 queued for processing (1 items on Q)
00:10:35.171539 SQW04 Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:35.178621 SQPmp Request 231 on socket 10 queued for processing (1 items on Q)
00:10:35.178663 SQW02 Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:38.119935 SQPmp Request 232 on socket 10 queued for processing (1 items on Q)
00:10:38.119984 SQW03 Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
Exception Object
[message:protected] => The virtual machine 'ubuntu-1' has terminated unexpectedly during startup because of signal 11
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /volume2/web/phpvirtualbox/endpoints/lib/vboxconnector.php
[line:protected] => 2429
[trace:Exception:private] => Array
[0] => Array
[file] => /volume2/web/phpvirtualbox/endpoints/lib/vboxconnector.php
[line] => 951
[function] => remote_progressGet
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[progress] => 265067e6c45d2f1d-0000000000000004
[1] => Array
[file] => /volume2/web/phpvirtualbox/endpoints/api.php
[line] => 316
[function] => __call
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[1] => Array
[0] => Array
[data] => Array
[responseData] => Array
[info] => Array
[completed] => 1
[canceled] =>
[description] => Starting VM
[operationDescription] => Creating process for virtual machine "ubuntu-1" (headless)
[timeRemaining] => Array
[timeElapsed] => Array
[days] => 16953
[hours] => 1
[minutes] => 55
[seconds] => 12
[percent] => 0
[success] => 1
[key] => 53474945cfd7ac0bf8114767c209c2a6
[errors] => Array
[persist] => Array
[messages] => Array
