Dec 30 16:36:15 kernel: arm4regs : 429.200 MB/sec
Dec 30 16:36:15 kernel: 8regs : 368.800 MB/sec
Dec 30 16:36:15 kernel: 32regs : 513.200 MB/sec
Dec 30 16:36:15 kernel: raid5: using function: 32regs (513.200 MB/sec)
Dec 30 16:36:15 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Dec 30 16:36:15 kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Dec 30 16:36:15 kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Dec 30 16:36:15 kernel: VFS: Mounted root (ext2 filesystem).
Dec 30 16:36:15 kernel: ds107+_synobios: module license 'Synology Inc.' taints kernel.
Dec 30 16:36:15 kernel: Brand: Synology
Dec 30 16:36:15 kernel: Model: DS-107+
Dec 30 16:36:15 kernel: synobios: unload
Dec 30 16:36:15 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Dec 30 16:36:15 kernel: VFS: Mounted root (ext3 filesystem).
Dec 30 16:36:16 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Dec 30 16:36:22 scemd: modules/disk_hibernation.c:79 Force hibernation enable, idle minutes 20
Dec 30 16:36:22 scemd: modules/raid_sys_volume_check.c:361 This model is not support raid system
Dec 30 16:36:23 synousbdisk: RCClean succeeded
Dec 30 16:58:13 kernel: drivers/scsi/sd.c (1711) Internal disk with bus id: 0
Dec 30 16:58:13 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Dec 30 16:58:13 kernel: DS406-0: Swapping erase regions for broken CFI table.
Dec 30 16:58:13 kernel: Mac1: 00:11:32:04:04:e8
Dec 30 16:58:13 kernel: vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
Dec 30 16:58:13 kernel: Vender partition MacNum:1 retlen:128
Dec 30 16:58:13 kernel: Serial Number: 89E3N00456
Dec 30 16:58:13 kernel: raid6: int32x1 29 MB/s
Dec 30 16:58:13 kernel: raid6: int32x2 45 MB/s
Dec 30 16:58:13 kernel: raid6: int32x4 51 MB/s
Dec 30 16:58:13 kernel: raid6: int32x8 48 MB/s
Dec 30 16:58:13 kernel: raid6: using algorithm int32x4 (51 MB/s)
Dec 30 16:58:13 kernel: arm4regs : 429.200 MB/sec
Dec 30 16:58:13 kernel: 8regs : 368.800 MB/sec
Dec 30 16:58:13 kernel: 32regs : 513.600 MB/sec
Dec 30 16:58:13 kernel: raid5: using function: 32regs (513.600 MB/sec)
Dec 30 16:58:13 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Dec 30 16:58:13 kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Dec 30 16:58:13 kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Dec 30 16:58:13 kernel: VFS: Mounted root (ext2 filesystem).
Dec 30 16:58:13 kernel: ds107+_synobios: module license 'Synology Inc.' taints kernel.
Dec 30 16:58:13 kernel: Brand: Synology
Dec 30 16:58:13 kernel: Model: DS-107+
Dec 30 16:58:13 kernel: synobios: unload
Dec 30 16:58:13 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Dec 30 16:58:13 kernel: VFS: Mounted root (ext3 filesystem).
Dec 30 16:58:14 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Dec 30 16:58:16 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Dec 30 16:58:22 scemd: modules/disk_hibernation.c:79 Force hibernation enable, idle minutes 20
Dec 30 16:58:22 scemd: modules/raid_sys_volume_check.c:361 This model is not support raid system
Dec 30 16:58:22 synousbdisk: RCClean succeeded
Dec 30 16:58:31 kernel: Got empty serial number. Generate serial number from product.
Dec 30 16:58:33 load [local] UPDATE: trigger.c (97) Failed to attach shared memory.
Dec 30 16:58:34 load [local] UPDATE: trigger.c (97) Failed to attach shared memory.
Dec 30 16:58:40 synorcd: hw_raytac.c (126) failed to open /dev/usb/hiddev5 (No such device).
Dec 30 16:59:18 afpd[2362]: DiskStation:AFPServer@* started on 65280.167:128 (2.0.1)
Dec 31 04:28:53 kernel: synobios: power button pressed, ret = 0
Dec 31 04:29:01 scemd: SCEMD: Shutdown the system.
Dec 31 04:29:02 findhostd: si_pid=[3115], process=[/bin/sh]
Dec 31 04:29:02 findhostd: si_ppid=[3114], process=[sh]
Dec 31 04:29:02 findhostd: findhostd.c:51(FHOSTDExit) exit on signal[10]
Dec 31 04:29:02 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
Dec 31 04:29:07 scheduler: scheduler.c (1297) Got signal. Die gracefully.
Dec 31 04:29:07 scheduler: scheduler.c (1315) rTorrent is killed.
Dec 31 04:29:09 syno_poweroff_task: lvm_poweroff.c:52 Failed to /sbin/vgchange -an > /dev/null 2>&1
Jan 2 04:45:04 kernel: CPU: ARM926EJ-Sid(wb) [41069260] revision 0 (ARMv5TEJ)
Jan 2 04:45:04 kernel: Machine: MV-88fxx81
Jan 2 04:45:04 kernel: Using UBoot passing parameters structure
Jan 2 04:45:04 kernel: Sys Clk = 166666667, Tclk = 166666667
Jan 2 04:45:04 kernel: Internal HD num: 0
Jan 2 04:45:04 kernel: Synology Hareware Version: DS107v30
Jan 2 04:45:04 kernel: Memory policy: ECC disabled, Data cache writeback
Jan 2 04:45:04 kernel: CPU0: D VIVT write-back cache
Jan 2 04:45:04 kernel: CPU0: I cache: 32768 bytes, associativity 1, 32 byte lines, 1024 sets
Jan 2 04:45:04 kernel: CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Jan 2 04:45:04 kernel: Built 1 zonelists
Jan 2 04:45:04 kernel: PID hash table entries: 1024 (order: 10, 16384 bytes)
Jan 2 04:45:04 kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 2 04:45:04 kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 2 04:45:04 kernel: Mount-cache hash table entries: 512
Jan 2 04:45:04 kernel: CPU Interface
Jan 2 04:45:04 kernel: -------------
Jan 2 04:45:04 kernel: SDRAM_CS0 ....base 00000000, size 128MB
Jan 2 04:45:04 kernel: SDRAM_CS1 ....disable
Jan 2 04:45:04 kernel: SDRAM_CS2 ....disable
Jan 2 04:45:04 kernel: SDRAM_CS3 ....disable
Jan 2 04:45:04 kernel: PEX0_MEM ....base e0000000, size 128MB
Jan 2 04:45:04 kernel: PEX0_IO ....base f2000000, size 1MB
Jan 2 04:45:04 kernel: PCI0_MEM ....base e8000000, size 128MB
Jan 2 04:45:04 kernel: PCI0_IO ....base f2100000, size 1MB
Jan 2 04:45:04 kernel: INTER_REGS ....base f1000000, size 1MB
Jan 2 04:45:04 kernel: DEVICE_CS0 ....base fa000000, size 2MB
Jan 2 04:45:04 kernel: DEVICE_CS1 ....base f8000000, size 32MB
Jan 2 04:45:04 kernel: DEVICE_CS2 ....base fa800000, size 1MB
Jan 2 04:45:04 kernel: DEV_BOOCS ....base ffc00000, size 4MB
Jan 2 04:45:04 kernel: Marvell USB EHCI Host controller #0: c0bf2e00
Jan 2 04:45:04 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jan 2 04:45:04 kernel: RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Jan 2 04:45:04 kernel: Marvell Gigabit Ethernet Driver 'egiga':
Jan 2 04:45:04 kernel: o Ethernet descriptors in DRAM
Jan 2 04:45:04 kernel: o DRAM SW cache-coherency
Jan 2 04:45:04 kernel: o Checksum offload enabled
Jan 2 04:45:04 kernel: o Loading network interface 'egiga0' as eth0
Jan 2 04:45:04 kernel: o Radom MAC address 00:a5:02:2c:65:df
Jan 2 04:45:04 kernel: ata1: Device not ready. Try to reset...
Jan 2 04:45:04 kernel: drivers/scsi/sd.c (1711) Internal disk with bus id: 0
Jan 2 04:45:04 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jan 2 04:45:04 kernel: DS406-0: Swapping erase regions for broken CFI table.
Jan 2 04:45:04 kernel: Mac1: 00:11:32:04:04:e8
Jan 2 04:45:04 kernel: vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
Jan 2 04:45:04 kernel: Vender partition MacNum:1 retlen:128
Jan 2 04:45:04 kernel: Serial Number: 89E3N00456
Jan 2 04:45:04 kernel: raid6: int32x1 29 MB/s
Jan 2 04:45:04 kernel: raid6: int32x2 45 MB/s
Jan 2 04:45:04 kernel: raid6: int32x4 51 MB/s
Jan 2 04:45:04 kernel: raid6: int32x8 48 MB/s
Jan 2 04:45:04 kernel: raid6: using algorithm int32x4 (51 MB/s)
Jan 2 04:45:04 kernel: arm4regs : 429.200 MB/sec
Jan 2 04:45:04 kernel: 8regs : 368.800 MB/sec
Jan 2 04:45:04 kernel: 32regs : 513.200 MB/sec
Jan 2 04:45:04 kernel: raid5: using function: 32regs (513.200 MB/sec)
Jan 2 04:45:04 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 2 04:45:04 kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Jan 2 04:45:04 kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Jan 2 04:45:04 kernel: VFS: Mounted root (ext2 filesystem).
Jan 2 04:45:04 kernel: ds107+_synobios: module license 'Synology Inc.' taints kernel.
Jan 2 04:45:04 kernel: Brand: Synology
Jan 2 04:45:04 kernel: Model: DS-107+
Jan 2 04:45:04 kernel: synobios: unload
Jan 2 04:45:04 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Jan 2 04:45:04 kernel: VFS: Mounted root (ext3 filesystem).
Jan 2 04:45:06 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
