Hi!
Meine lokale Datensicherung auf eine ext. USB-Platte bricht immer wieder ab. Platte ist dann offline...
"Local Backup Failed"
Die Platte ist frisch ext4-formatiert. e2fsck findet keine Fehler. Mehrmals versucht.
Dann die Platte NTFS-formatiert und das Backup lief (sehr langsam) durch...
DS210j / DSM 4.0beta.
Hat jemand einen Tipp, woran es liegen könnte?
Grüße Flo
Grüße Flo
messages schrieb:Jan 22 23:43:06 kernel: [ 6817.000000] usb 1-1.2: lock for hub EH
Jan 22 23:43:07 kernel: [ 6817.190000] usb 1-1.2: unlock for hub EH
Jan 22 23:44:07 kernel: [ 6878.000000] usb 1-1.2: lock for hub EH
Jan 22 23:44:08 kernel: [ 6878.120000] hub is performing EH
Jan 22 23:44:08 kernel: [ 6878.380000] hub is performing EH
Jan 22 23:44:08 kernel: [ 6878.630000] hub is performing EH
Jan 22 23:44:09 kernel: [ 6878.640000] usb 1-1.2: unlock for hub EH
Jan 22 23:44:09 kernel: [ 6878.670000] end_request: I/O error, dev sdr, sector 252176016
Jan 22 23:44:09 kernel: [ 6878.670000] Buffer I/O error on device sdr1, logical block 31521970
Jan 22 23:44:09 kernel: [ 6878.680000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.690000] Buffer I/O error on device sdr1, logical block 31521971
Jan 22 23:44:09 kernel: [ 6878.690000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.700000] Buffer I/O error on device sdr1, logical block 31521972
Jan 22 23:44:09 kernel: [ 6878.700000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.710000] Buffer I/O error on device sdr1, logical block 31521973
Jan 22 23:44:09 kernel: [ 6878.710000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.720000] Buffer I/O error on device sdr1, logical block 31521974
Jan 22 23:44:09 kernel: [ 6878.730000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.730000] Buffer I/O error on device sdr1, logical block 31521975
Jan 22 23:44:09 kernel: [ 6878.740000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.740000] Buffer I/O error on device sdr1, logical block 31521976
Jan 22 23:44:09 kernel: [ 6878.750000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.750000] Buffer I/O error on device sdr1, logical block 31521977
Jan 22 23:44:09 kernel: [ 6878.760000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.760000] Buffer I/O error on device sdr1, logical block 31521978
Jan 22 23:44:09 kernel: [ 6878.770000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.780000] Buffer I/O error on device sdr1, logical block 31521979
Jan 22 23:44:09 kernel: [ 6878.780000] lost page write due to I/O error on sdr1
Jan 22 23:44:09 kernel: [ 6878.790000] sd 3:0:0:0: rejecting I/O to offline device
Jan 22 23:44:09 kernel: [ 6878.810000] end_request: I/O error, dev sdr, sector 252176256
Jan 22 23:44:09 kernel: [ 6878.820000] sd 3:0:0:0: rejecting I/O to offline device
Jan 22 23:44:09 kernel: [ 6878.830000] sd 3:0:0:0: rejecting I/O to offline device
Jan 22 23:44:09 kernel: [ 6878.840000] JBD2: Detected IO errors while flushing file data on sdr1-8
Jan 22 23:44:09 kernel: [ 6878.840000] sd 3:0:0:0: rejecting I/O to offline device
Jan 22 23:44:09 kernel: [ 6878.870000] Aborting journal on device sdr1-8.
Jan 22 23:44:09 kernel: [ 6878.870000] sd 3:0:0:0: rejecting I/O to offline device
Jan 22 23:44:09 kernel: [ 6878.870000] JBD2: I/O error detected when updating journal superblock for sdr1-8.
Jan 22 23:44:09 kernel: [ 6878.880000] EXT4-fs error (device sdr1): ext4_journal_start_sb: Detected aborted journal
Jan 22 23:44:09 kernel: [ 6878.890000] EXT4-fs (sdr1): Remounting filesystem read-only
Jan 22 23:44:09 kernel: [ 6878.910000] JBD2: Detected IO errors while flushing file data on sdr1-8
Jan 22 23:44:09 synolocalbkp: synocopyfile.c:155 Fail to write file /volumeUSB2/usbshare/LocalBackup/Bilder/P1040478.JPG!! errno=[30/Read-only file system]
