Kernelmodule für USB
JoachimS
29. Dez 2009
Hi Franzl,
bei mir klappt es leider nicht ganz:
insmod ftdi_sio.ko vendor=0x0403 product=0xf06a
kennt parameter vendor nicht.
insmod usbserial.ko vendor=0x03eb product=0x204b
ging
dmesg
[3916895.790000] usbserial: Unknown parameter `vendor'
[3916920.110000] usbcore: registered new interface driver usbserial
[3916920.120000] usbserial: USB Serial Driver core
[3916941.580000] USB Serial support registered for FTDI USB Serial Device
[3916941.610000] usbcore: registered new interface driver ftdi_sio
[3916941.610000] ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver
[3917856.490000] usbcore: deregistering interface driver ftdi_sio
[3917856.490000] USB Serial deregistering driver FTDI USB Serial Device
[3917925.910000] USB Serial support registered for FTDI USB Serial Device
[3917925.940000] usbcore: registered new interface driver ftdi_sio
[3917925.940000] ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver
[3924343.510000] usb 1-1.3.4: USB disconnect, address 6
[3924350.150000] usb 1-1.3.4: new full speed USB device using orion-ehci and address 10
[3924350.260000] usb 1-1.3.4: configuration #1 chosen from 1 choice
[3924350.270000] Got empty serial number. Generate serial number from product.
Normalerweise muesste es so aussehen:
usbcore: registered new interface driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
usb 1-1.3.3: new full speed USB device using ehci_marvell and address 6
usb 1-1.3.3: configuration #1 chosen from 1 choice
ftdi_sio 1-1.3.3:1.0: FTDI USB Serial Device converter detected
drivers/usb/serial/ftdi_sio.c: Detected FT232BM
usb 1-1.3.3: FTDI USB Serial Device converter now attached to ttyUSB2
Hast Du ne Idee woran es liegt?
Gruss Joachim
zentis666
08. Dez 2008
Hallo!
Hab es leider immer noch nicht hinbekommen, aber vielleicht bekommt es jemand mit mehr Erfahrung hin.
Nach dem 3rd Party Apps Integration Guide und ein bischen rumgesuche bekommt man das entsprechende .config-File für die benötigte Plattform aus den Sourcen: http://sourceforge.net/projects/dsgpl/files/
(Hatte anfangs gar nicht gesehen was hier noch so alles liegt ;-)
Die .configs für die unterschiedlichen Architekturen liegen unter /linux-2.6.32/synoconfigs. Dort findet man auch usb-serial.c usw., unter /linux-2.6.32/drivers/usb/serial.
Kann damit jemand funktionierende Module bauen?
Laut diesem Guide bekomme ich es nicht hin, man soll das Ganze per make oldconfig und make menuconfig konfigurieren, ich scheitere allerdings schon bei der Prozessorauswahl (hab einen freescale mpc8543 PPC Prozessor, unter freescale finde ich aber nichts passendes). Und wenn ich dann durch das weitere config-Programm gehe, weiss ich ehrlich gesagt bei kaum einem der Punkte was genau eingetragen werden muss :mad:
AkeSeMu
02. Nov 2009
Hallo!
Ok, da ich den Thread vor über einem Jahr losgetreten und mittlerweile eine Cross-Dev-VM nur für die Synology aufgesetzt habe und es ja auch bald Weihnachten ist ;)... hier die beiden Module für ppc853x Kisten (z.B. 109+... bitte hier überprüfen, ob Deine Synology die passende CPU hat).
Sind noch ganz frisch dampfend, gestern für mein DSM 3.0-1354 gebaut und getestet.
Hier downloaden
Viel Erfolg und Spaß damit,
AkeSeMu
zentis666
08. Dez 2008
AkeSeMu
Hallo AkeSeMu,
danke erstmal für die Module!
Ich bekomme leider folgende Meldung wenn ich Dein usbserial Modul laden will:
insmod: error inserting 'usbserial.ko': -1 Unknown symbol in module
Zentis
JoachimS
29. Dez 2009
Hallo AkeSeMu,
habe leider ne 209, könntest Du bitte für die Plattform die USB Module auch bilden?
Thx Joachim
AkeSeMu
02. Nov 2009
Hallo Zentis,
Ich vermute mal, daß Du einen älteren Kernel hast. Wie gesagt habe ich mit den aktuellsten Synology Kernel-sourcen (2.6.32) compiliert.
Mit 'uname -a' auf der shell solltest Du sehen, was für einen Kernel und welche CPU Du hast.
Mit 'dmesg' nach einem fehlgeschlagenen 'insmod' könntest Du evtl. sehen, was da knirscht...
Viele Grüße, AkeSeMu
AkeSeMu
02. Nov 2009
Synology Weihnachts-Modulbasteleien
Hallo Joachim,
Hallo AkeSeMu,
Sorry, auch wenn bald Weihnachten ist, ich kann nicht für all die verschiedenen CPUs, die in den Synology boxen verbaut wurden/werden, module bauen.
Aaaaber, es ist sicher lohnend sich selbst mal in das Prozedere einzuarbeiten... die nächste Firmware kommt bestimmt! Ist wirklich nicht schwer. Hier ein schnelles how-to:
1) Man besorge sich eine VM Lösung, z.B. VM-Ware oder Parallels oder ähnliches (gibt alles auch als free-variante) und installiert ein x86-Linux darauf.
2) Man holt sich die cross-compiler ("Tool chain") passend zur Syno-CPU hier und packt das in /usr/local in der VM aus.
3) Man holt sich die Kernel sources hier und packt diese z.B. nach /usr/local/source_2.6.32 aus.
4) Wechselt darin in das "linux-2.26.32" Verzeichnis. Hier gibt es einen Ordner 'synoconfigs'. Kopiere das passende Config-File aus diesem Ordner in den Source-root als Datei '.config' (z.B. cp synoconfigs/ppc854x ./.config)
5a) 'make menuconfig' - nach einer Weile bekommt man das Kernel config menü und kann die entsprechenden Module, die gebaut werden sollen, auswählen. (Also [M] auswählen, Siehe hier)
5b) Kernel bauen mit 'make'
5c) Module bauen mit 'make modules'
6) Die module aus ./arch/powerpc/drivers/usb/[rest vergessen, musst Du nachschauen] auf die Synology kopieren....
7) Device auf der Synology erstellen mit 'mknod /dev/ttyUSB0 c 188 0'
8) Fertig! Nun solltest Du die Module mit 'insmod' laden können.
itari
15. Mai 2008
Ich hab mal den Thread-Titel ein wenig abgeändert, da sich ja das Thema weiterentwickelt hat. Ist das ok so?
Itari
JoachimS
29. Dez 2009
Hallo AkeSeMu,
Danke für die Anleitung.
Was mir nicht klar ist, sind die USB Module bei den Kernel sources schon dabei oder wo bekomme ich die her?
Hier ist auch noch ne Anleitung. Die Module passen sogar für meine CPU aber sie untestützen keine Parameter wie zB vendor=...
Wo bekomme ich die denn her?
Thx Joachim
Lacknone
13. Okt 2008
Hy Zusammen,
da ich nicht immer auf andere angewiesen sein wollte, dachte ich mir, ich kompiliere als "Newbie" mir die Treiber selbst anhand der Anleitung von AkeSeMu.
Leider stoße ich hier an die Grenzen meiner Fähigkeiten :(
Ich habe mir den VMware-Player heruntergeladen und darin das aktuelle Ubuntu installiert.
Ich habe mich an die folgenden Schritte von AkeSeMu gehalten:
Dies musste ich unter Ubuntu ja schon mit "sudo" ausführen, da ich es nicht mit root ausführen konnte.
Allerdings bekomme ich bei make menuconfig bereits nen Fehler (ausm Gedächtnis "...no target.... stop")
Jetzt meine Frage, kann mir hier jemand etwas Hilfestellung geben? Ist Ubuntu dafür evtl. nicht geeignet? Was wäre euer Vorschlag?
Danke vorab schon für eure Hilfe
JoachimS
29. Dez 2009
ich werde mich demnächst auch dran machen.
Ich vermute mal, dass Du den TARGET-PREFIX nicht richtig gesetzt hast.
Siehe hier, oder hier oder hier
Gruss Joachim
Lacknone
13. Okt 2008
Nochmal ich :rolleyes:
Bin in der Zwischenzeit etwas weitergekommen.
Da es mir ja nur um die Seriellen USB-Treiber geht, die ich benötige habe ich nun folgendes gemacht:
linux-1rxw:/usr/local/source/linux-2.6.32 # make ARCH=powerpc \CROSS_COMPILE=/usr/local/powerpc-linux-gnuspe/bin/powerpc-linux-gnuspe- modules
scripts/kconfig/conf -s arch/powerpc/Kconfig
# configuration written to .config
  CHK     include/linux/version.h
  LD [M]  drivers/usb/core/usbcore.o
  CC [M]  drivers/usb/serial/usb-serial.o
  CC [M]  drivers/usb/serial/generic.o
  CC [M]  drivers/usb/serial/bus.o
  LD [M]  drivers/usb/serial/usbserial.o
  CC [M]  drivers/usb/serial/ftdi_sio.o
Was ich jetzt wieder gar nicht verstehe, warum er mir die Treiber nicht richtig macht?
Das erwartete Ergebnis hätte dann lauten müssen:
-usbserial.ko
-ftdi_sio.ko
Warum kam dabei jetzt aber nur *.o raus?
Hat mir hier jemand vielleicht eine Antwort?
Danke im Voraus.
Lacknone
alochter
08. Nov 2009
ich mühe mich auch seit einiger Zeit mit einem usbserial.ko (vom polnischen Server) ab. Ich benötige es auf meiner DS209 (DSM 2.2 / Kernel 2.6.24) um FHEM (Hausautomation) zum Laufen zu bekommen. Leider disconnected das Kernel Modul oft nach einiger Zeit mit der Meldung:
Apr 5 15:45:08 kernel: usbserial_generic 1-1.3:1.0: Generic device with no bulk out, not allowed.
Apr 5 15:45:08 kernel: usbserial_generic: probe of 1-1.3:1.0 failed with error -5
Kann mir jemand weiterhelfen und mir evtl. das passende cdc-acmd Modul zukommen lassen?
Gruss,
Arne
