bekomme schon seit Wochen diese mails, kann ich aber nicht so wirklich einordnen. Ist das Müll oder wichtig?
Wolfi (s.u.)
Rechner: MacBookPro 17"(early 2011)OSX 10.7.5, NAS: DS416play (8GbRam)4x4TB OSaktuell, TV: LG OLED 55D6B,
UHD BD Player: Panasonic UB-900, Router: Fritzbox 6490 Cable (Vodafone)
Von: Synology eNews <noreply@synologynotification.com>
Security Advisory
Severity
Important
Ongoing
Abstract
Multiple security vulnerabilities have been found in Wget, and may allow man-in-the-middle attackers to execute arbitrary codes, or cause denial-of-service attack from a vulnerable version of Synology DiskStation Manager (DSM), Synology Router Manager (SRM), and Download Station.
Severity
CVE-2017-13089
Impact: Important
CVSS3 Base Score: 7.3
CVSS3 Base Metrics: CVSS:3.0/AV:L/AC:L/PR:L/UI:R/S:U/C:H/I:H/A:H
CVE-2017-13090
Impact: Important
Affected
Products
DSM 6.1
DSM 6.0
DSM 5.2
SRM 1.1
Download Station before 3.8.7-3490
Models
All Synology models
Description
CVE-2017-13089 The http.c:skip_short_body() function is called in some circumstances, such as when processing redirects. When the response is sent chunked in wget before 1.19.2, the chunk parser uses strtol() to read each chunk's length, but doesn't check that the chunk length is a non-negative number. The code then tries to skip the chunk in pieces of 512 bytes by using the MIN() macro, but ends up passing the negative chunk length to connect.c:fd_read(). As fd_read() takes an int argument, the high 32 bits of the chunk length are discarded, leaving fd_read() with a completely attacker controlled length argument.
CVE-2017-13090 The retr.c:fd_read_body() function is called when processing OK responses. When the response is sent chunked in wget before 1.19.2, the chunk parser uses strtol() to read each chunk's length, but doesn't check that the chunk length is a non-negative number. The code then tries to read the chunk in pieces of 8192 bytes by using the MIN() macro, but ends up passing the negative chunk length to retr.c:fd_read(). As fd_read() takes an int argument, the high 32 bits of the chunk length are discarded, leaving fd_read() with a completely attacker controlled length argument. The attacker can corrupt malloc metadata after the allocated buffer.
Mitigation
None
Update Availability
To fix the security issues: please go to DSM > Package Center and update Download Station to 3.8.7-3490 or above.
Reference
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13089
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13090
https://access.redhat.com/security/cve/cve-2017-13089
https://access.redhat.com/security/cve/cve-2017-13090
Abmelden Change Settings Terms & Conditions Privacy Policy
Copyright © 2017 Synology Inc. All rights reserved.
Wolfi (s.u.)
Security Advisory
Severity
Important
Ongoing
Abstract
Severity
CVE-2017-13089
Impact: Important
CVE-2017-13090
Impact: Important
Affected
Products
DSM 6.1
DSM 6.0
DSM 5.2
SRM 1.1
Models
All Synology models
Description
Mitigation
None
Update Availability
Reference
