DDNS Updater DSM 4.3 Released
redwineman
04. Aug 2013
It appears Synology DSM 4.3 has justed been released. Are there any issues running DDNS Updater on this new software level.
Also if I have two different domains at NameCheap can I create to different entries two update them.
Thanks for the great support
Craig
ArnoNuem
11. Dez 2007
I updated my DS213 to DSM4.3 yesterday. But now DDNS Updater does not start. It only pops up an empty window with message: 403 Forbidden.
Please help.
Kind regards
ArnoNuem
Matthieu
03. Nov 2008
Are you using an older version of DDNSupdater?
AFAIK, the most recent version worked with DSM 4.3 beta (and there are no signs yet that this changed with the final). However, as Synology changed authentication to something more secure, you will have to disable the new feature called "protection against cross-site request forgery attacks" (last point in the 4.3 changelog). This can be done in the user's settings.
BTW: The background process should be running anyway. Only the GUI is not accessible.
Regards,
Matthieu
ArnoNuem
11. Dez 2007
Ok, after a look into the 4.3 beta thread I found a workaround to disable the protection against Cross-Site-Request-Forgery in the secutity settings of the DSM settings.
Now DDNS Updater is working.
Edit: Thanks Matthieu! That matches with my findings.
ArnoNuem
QTip
Super-Moderator
Teammitglied
04. Sep 2008
The upcoming version of DDNS updater can be run with enabled "protection against cross-site request forgery".
Craig
To come back to your question: yes you can create as many entries you want
redwineman
04. Aug 2013
That is good news on both questions. When do you think the new version will be available. Thanks as always for your support.
Craig
