- Mitglied seit
- 23. Jan 2011
- Punkte für Reaktionen
- 0
Hallo zusammen
Folgendes wie dem titel zuentnehmen ist habe ich eine DS209+II und würde gerne IPKG installieren.Jedoch kommen immer fehler meldungen die wie folgt aussehen.
Benütze Für PowerPC (ppc_85xx): http://ipkg.nslu2-linux.org/feeds/o...nstable/syno-e500-bootstrap_1.2-7_powerpc.xsh
sollte glaub das richtige sein.
Hier nun die fehler.
Big_Chris> sh syno-e500-bootstrap_1.2-7_powerpc.xsh
Optware Bootstrap for syno-e500.
Extracting archive... please wait
bootstrap/
bootstrap/bootstrap.sh
bootstrap/ipkg-opt.ipk
bootstrap/ipkg.sh
bootstrap/optware-bootstrap.ipk
bootstrap/wget.ipk
1330+1 records in
1330+1 records out
Creating temporary ipkg repository...
Installing optware-bootstrap package...
Unpacking optware-bootstrap.ipk...Done.
Configuring optware-bootstrap.ipk...mount: mounting /volume1/@optware on /opt failed: No such file or directory
mkdir: can't create directory '/opt/etc': No such file or directory
chmod: /opt/etc: No such file or directory
mkdir: can't create directory '/opt/var/': No such file or directory
chmod: /opt/var: No such file or directory
mkdir: can't create directory '/opt/tmp': No such file or directory
chmod: /opt/tmp: No such file or directory
mkdir: can't create directory '/opt/lib': No such file or directory
chmod: /opt/lib: No such file or directory
//tmp/ipkg/info/optware-bootstrap.ipk.preinst failed. Aborting installation of optware-bootstrap.ipk
Installing ipkg...
Unpacking ipkg-opt.ipk...Done.
Configuring ipkg-opt.ipk...WARNING: can't open config file: /usr/syno/ssl/openssl.cnf
tar: can't make dir ./opt/share: No such file or directory
tar: can't create directory './opt/share': No such file or directory
tar: can't make dir ./opt/share/ipkg: No such file or directory
tar: can't create directory './opt/share/': No such file or directory
tar: can't make dir ./opt/share/: No such file or directory
tar: can't open './opt/share/': Is a directory
Done.
Removing temporary ipkg repository...
Installing wget...
bootstrap.sh: line 55: /opt/bin/ipkg: not found
Ich bin recht unerfahren mit dem ganzen konsolenzeug und alles. ich hoffe mir kann jemand helfen. übrigens das ganze wurde als Root ausgeführt nicht als admin.
Wäre dankbar für jede hilfe. PS.vielicht auch noch andere die das selbe problem haben.
schönen abend noch gruss chris
bootstrap/
bootstrap/ipkg.sh
bootstrap/wget.ipk
1330+1 records in
1330+1 records out
Installing ipkg...
Done.
Installing wget...
