Hallo!
Seit dem ich auf den DSM 3.2-1944 geupdatet habe, läuft mein Backup auch nicht mehr durch.
Ständig bekomme ich die Meldung, dass das Backup abgebrochen wurde. Zuerst brach es nach zirka 9 Stunden ab, danach schon innerhalb einer halben Stunde.
- Local Backup failed
- External Disk [USB Disk blablabla] is ejected
in \var\log\messages finden sich folgende Meldungen:
Nov 8 16:41:58 synnas kernel: [249771.080000] end_request: I/O error, dev sdq, sector 1074816
Nov 8 16:41:58 synnas kernel: [249771.090000] Buffer I/O error on device sdq1, logical block 134320
Nov 8 16:41:58 synnas kernel: [249771.100000] Buffer I/O error on device sdq1, logical block 134321
Nov 8 16:41:58 synnas kernel: [249771.110000] Buffer I/O error on device sdq1, logical block 134322
Nov 8 16:41:58 synnas kernel: [249771.120000] Buffer I/O error on device sdq1, logical block 134323
Nov 8 16:41:58 synnas kernel: [249771.130000] Buffer I/O error on device sdq1, logical block 134324
Nov 8 16:41:58 synnas kernel: [249771.150000] Buffer I/O error on device sdq1, logical block 134325
Nov 8 16:41:58 synnas kernel: [249771.160000] Buffer I/O error on device sdq1, logical block 134326
Nov 8 16:41:58 synnas synolocalbkp: synocopyfile.c:155 Fail to write file /volumeUSB2/usbshare/LocalBackup/Backup/Laptop/Music/iTunes/iTunes Media/Mobile Applications/eBay 2.3.0.ipa!! errno=[30/Read-only file system]
Nov 8 16:41:58 synnas synolocalbkp: synocopyfile.c:99 Failed to open file [/volumeUSB2/usbshare/LocalBackup/Backup/Laptop/Music/iTunes/iTunes Media/Mobile Applications/The Sims 3.ipa], errno=[2/No such file or directory]
Nov 8 16:41:58 synnas kernel: [249771.170000] Buffer I/O error on device sdq1, logical block 134327
Nov 8 16:41:58 synnas kernel: [249771.180000] Buffer I/O error on device sdq1, logical block 134328
Nov 8 16:41:58 synnas kernel: [249771.190000] Buffer I/O error on device sdq1, logical block 134329
Nov 8 16:41:58 synnas kernel: [249771.230000] end_request: I/O error, dev sdq, sector 1075056
Nov 8 16:41:58 synnas kernel: [249771.270000] end_request: I/O error, dev sdq, sector 986056
Nov 8 16:41:58 synnas kernel: [249771.300000] Aborting journal on device sdq1-8.
Nov 8 16:41:58 synnas kernel: [249771.300000] JBD2: I/O error detected when updating journal superblock for sdq1-8.
Nov 8 16:41:58 synnas kernel: [249771.310000] EXT4-fs error (device sdq1): ext4_journal_start_sb_sync: Detected aborted journal
Nov 8 16:41:58 synnas kernel: [249771.320000] EXT4-fs (sdq1): Remounting filesystem read-only
Nov 8 16:41:58 synnas kernel: [249771.320000] EXT4-fs (sdq1): ext4_da_writepages: jbd2_start: 8192 pages, ino 875; err -30
Nov 8 16:41:58 synnas kernel: [249771.350000] EXT4-fs error (device sdq1) in ext4_reserve_inode_write: Journal has aborted
Nov 8 16:41:58 synnas kernel: [249771.360000] EXT4-fs error (device sdq1) in ext4_dirty_inode: Journal has aborted
Nov 8 16:41:58 synnas kernel: [249771.670000] EXT4-fs error (device sdq1): ext4_find_entry: reading directory #2 offset 0
Kann damit jemand was anfangen?
Bei den vorigen Firmwareversionen ging der Backupvorgang immer tadellos!
Für Hilfe wär ich echt dankbar!
