Synology Version: 1.1.6-6931
Perry2000
05. Nov 2012
Version: 1.1.6-6931
(2017-12-19)
What's New
IGMP snooping for Wi-Fi interface is now enabled by default.
2.4 GHz Wi-Fi can now be implemented with a channel bandwidth of 40 MHz.
Updated GeoIP and URL Blocker databases.
Improved CPS (connection per second) with CTF enabled on an RT1900ac.
Added support for IPv6 6rd.
Fixed Issues
Fixed an issue where the settings of Internet Allowed Time in Parental Control could not be restored.
Fixed an issue where SSL VPN might return a 403 forbidden page when the Prevention mode is enabled in IPS.
Fixed an issue where SRM might fail to access the Internet when the the VPN service provider's ID contains a colon :)).
Fixed an issue where a client device might fail to connect to Wi-Fi with the WPS PIN code.
Fixed an issue where an error message might display when the SSID contains non-alphanumerics and is longer than 32 characters.
Fixed an issue where traffic reports might fail to be generated when an external storage is removed.
Fixed an issue where a user could not select the proper channel for 2.4 GHz Wi-Fi after a change in country/region.
Fixed an issue where NAT-related rules might to be in effect for the secondary WAN interface upon its lack of gateway information.
Fixed an issue regarding user's interface operation on Safari 11.
Fixed an issue where the access to Internet using PPPoE might fail after Synology Router restarts.
Fixed an issue where SRM might not work properly when a client device is connected through 802.11b/g.
Fixed an issue of wrong time zone for Turkey.
Fixed an issue where Synology Router might restart unexpectedly.
Fixed an issue where SRM might not work properly with a certain LTE dongle.
Fixed an issue where Traffic Control might not work properly when Layer 7 monitor is enabled and a packet length is more than 16,834 bits.
Security Updates
Fixed a security vulnerability regarding Linux kernel (CVE-2017-16939).
Fixed a security vulnerability (Synology-SA-17:79).
Dauert schon ein paar Minuten. Bis jetzt läuft alles. VPN+ über die App geht.
heimo007
17. Aug 2010
seit dem Update auf Version: 1.1.6-6931 meines Routers RT1900ac funktioniert die Datenflusskontrolle nicht mehr. Kann noch alles einstellen aber die Clients machen trotzdem was sie wollen und belegen die ganze Bandbreite. Trotz Reduzierung der Bandbreite der betreffenden Clients auf <2KB/s.
Kann das jemand bestätigen?
Perry2000
05. Nov 2012
Zur Datenflusskontrolle kann ich nix sagen, da ich die nie nutze.
VPN+ übers Web geht jetzt auch wieder wie es soll.
Geo2810
25. Jun 2016
Hello
kennt das Problem jemand
mein Netzwerk läuft ohne Probleme und der Router meckert er kommt nicht ins netz :-(
Router neustart habe bereits durchgeführt
Perry2000
05. Nov 2012
Geht der Link "Was ist neu?"? Wenn ja, funktioniert das Web. Wurde eventuell auch diese Version zurück gezogen.....?
Wundern tut mich nix mehr. Es ist jetzt auch eine neue Version VPN+ da. Ich werds mal testen ;-)
Perry2000
05. Nov 2012
Lach!!!!
VPN+ Update wurde zurück gezogen.
Gestern noch die Update Meldung erhalten, nun wollte ich das erledigen und es ist kein Update mehr da.
Die haben es echt im Griff.....
heimo007
17. Aug 2010
Lach!!!!
Na super,
und ich hab den Mist drauf und hab arge Probleme mit der Datenflusskontrolle.
Kommt man irgendwie zurück auf die alte Version?
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
zurück geht es nur per deinstallieren und neu installieren.
PS: Bitte keine Vollzitate und besonders nicht wenn Du direkt antwortest.
Danke.
Perry2000
05. Nov 2012
Ich glaube das einfach nicht.
Heute Mittag wieder eine Email dass ein Update vorhanden ist.
Nun bin ich zu Hause, kein Update verfügbar.....
Die spinnen die Römer!
Vielleich kannst Du die alte Version noch vom Server laden und installieren?
heimo007
17. Aug 2010
Hallo Götz, vielen Dank für den Tip.
Gibt es eine Anleitung für die Deinstallation, oder reicht es den Router auf Werkseinstellungen zurück zu setzen. Andere Optionen konnte ich im SRM nicht finden.
Heiko
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
der Router sollte doch wohl auch das Paketzentrum haben und dort sollte es möglich sein das Paket zu entfernen.
Perry2000
05. Nov 2012
Das ist so wie es goetz sagt.
Paketzentrum
Paket XY deinstallieren
Dann das gewünschte Paket manuell installieren
heimo007
17. Aug 2010
Hallo, das weiß ich auch.
Ich rede aber nicht von einem Paketupdate, sondern von dem SRM Update (siehe Eingangsbeitrag)
Sorry für das Missverständnis, aber ich benötige eine Lösung um auf die vorherige SRM-Version zu gelangen.
Perry2000
05. Nov 2012
Ach sooo!
Datenflusskontrolle ist ja kein Paket, sorry :)
Dann kann ich auch nicht helfen. Wenn zurücksetzen nicht geht, kann wohl nur der Support helfen...
vaszago
09. Sep 2012
Neues Update ist draußen. Hab´s erfolgreich Installiert. Bis jetzt nichts negatives Aufgefallen.
heimo007
17. Aug 2010
Update drauf, aber Datenflusskontrolle immer noch ohne Funktion.
Perfekt.:(
vaszago
09. Sep 2012
Habe mit dieser Version auch so meine Probleme. 1-2 Tage ist die Internetverbindung Stabil und danach wirds instabil. Oft länger kein Internet dann gehts wieder. Da hilft nur mehr ein Neustart und dann gehts wieder 1-2 Tage und dann wieder instabiles Internet.
Schon ärgerlich. Da muss Synology nachbessern.
TM69
26. Aug 2016
irgendwie habe ich das Gefühl das bei der 1.1.6 irgendwas mit dem WLan nicht stimmt. Ich habe jetzt die Version 1.1.6-6931-1 drauf und sporadisch fliegen meine WLans weg. Geräte die drin sind fliegen raus und können sich nicht mehr anmelden. Mein Android Handy bleibt beim beziehen der IP hängen. Einzinste was hilft ist ein Neustart oder die WLANs aus und wieder einzuschalten. Ein Dauerzustand kann das nicht sein ... oder hat jemand eine Lösung dafür ?
Rones
28. Sep 2014
Ich hänge mich an den letzten Post mal übereinstimmend mit dran: wir haben in der Firma auch den RT1900ac als Access-Point mit RADIUS- und Directory-Server auf einem Synology-NAS im Einsatz und müssen seit dem Update auf die 1.1.6er-Versionen mehrmals täglich das WLAN aus- und wieder anschalten, damit es läuft.
Leider gibts es in diesem Thread bisjetzt noch keine Antwort. Wer ist noch alles betroffen und weiß jemand was näheres?
TheTwist76
21. Apr 2013
Wurde von denen die hier über Probleme mit dieser Firmware Version berichten ein Ticket bei Synology eröffnet?
Nur hier im Forum schreiben bringt nix. Gerade als Firma würde ich gleich ein Ticket aufmachen......
Leider geht das aus Euren Post nicht hervor.....
