DSM 6.x und darunter DSM 5.1 (5004) - Erfahrungen, Probleme, Bugs
TheTwist76
21. Apr 2013
Hi zusammen,
ich habe mal einen neuen Thread zur Finalen Version der DSM 5.1-5004) aufgemacht.
Hier könnt Ihr von Problemen oder Bugs in der Finalen DSM Version 5.1-5004 berichten.
Torrent-Mirror: http://torrent.10trum.de
Changelog: (ohne Pakete)
Compatibility and Installation
  1. DSM 5.1 can only be installed on Synology products running DSM 5.0. Before starting, please log in to DSM and go to Control Panel > Update & Restore > DSM Update to install the latest DSM.
  2. Some features have specific hardware requirements and therefore are only available on certain Synology NAS products.
  3. Weather information in the DSM login page and CIFS Scale-Out Cluster will neither be available nor supported in DSM 5.1.
What's New in DSM 5.1
  1. Security Advisor
    • Security Advisor is a DSM security application that scans your DSM settings and Synology NAS and recommends changes that help keep your Synology NAS safe.
  2. AppArmor
    • Application Armor kernel security module is now enabled in DSM. Each system program is associated with a security profile that restricts certain functions, protecting against unknown threats from malicious software.
  3. Service by Interface
    • You can set the network interface that each service will use in Control Panel > Info Center > Service.
  4. App Privileges
    • You can assign application privileges for local and domain groups.
    • You can define application privileges according to IP address.
  5. DSM Auto Update
    • You can create a schedule to install DSM updates automatically to keep your Synology NAS up-to-date.
  6. Package Center
    • Trust level protects you from installing altered packages or packages from unknown sources on your Synology NAS.
  7. 2-step verification enforcement
    • 2-step verification can be enforced on admin groups or all users.
  8. Backup and Replication
    • You can now back up data from any Synology NAS (A) to a volume on another Synology NAS (B) using its non-admin account (on B) with network backup destination privileges.
    • Added backup destination support for Azure, SFR S3, and hicloud S3.
    • The following packages can now be backed up via the built-in Backup & Replication feature: VPN Server, DNS Server, Mail Server, Proxy Server, RADIUS Server, Directory Server, and Asterisk.
  9. LUN Backup
    • iSCSI LUN network backup performance has been enhanced by 169%, as illustrated in the below comparison:
    Local Backup445 MB/s863 MB/s94%
    Network Backup129 MB/s348 MB/s169%
  10. iSCSI LUN Snapshots
    • You can set a schedule for creating iSCSI LUN application-consistent snapshots to continuously protect your LUN.
    • You can lock a specific snapshot to prevent it from being removed by retention policy.
  11. iSCSI LUN Allocation Unit Size
    • You can configure the iSCSI LUN using advanced features to optimize the performance.
  12. VMware VAAI NAS
    • Added NFS support for two primitives: Full File Clone and Reserve Space.
    • Please note that you should install the Synology NFS Plug-in for VMware VAAI and read the instructions in README.txt to make sure installation is successful.
  13. UNMAP Support for Windows Server 2012
    • Added support for Storage Space Reclamation via UNMAP command, which can be triggered by file deletion or a file system level trim.
  14. SSD Cache
    • You can now create a read-only cache with one SSD.
    • SSD read hit rate is displayed in real-time as well as daily, weekly, and monthly intervals.
    • SSD Cache Advisor helps you determine the required SSD cache size.
  15. High Availability Manager
    • Added Read/Write SSD Cache support for HA cluster.
    • High Availability is now built-in for DSM 5.1.
  16. File Station
    • You can manage and transfer files to another WebDAV/FTP server.
    • Added support for FTP, SFTP, WebDAV, and WebDAV over HTTPS.
    • You can share files as attachments using a simple email client.
    • You can use the smart drag and drop feature to apply different actions to each copy or move file conflict.
    • You can share files to DSM users and they will receive notifications.
    • You can now play music using the built-in audio player.
  17. IPv6
    • Added IPv6 support for VPN client, Log Center, QuickConnect and DDNS.
  18. Static Route and Multiple Gateways
    • You can set the default gateway on each network interface.
    • You can define static routes based on your network environment.
    • You can use the IP Routing Table to view how network packets will be routed.
  19. Storage Analyzer
    • Storage Analyzer allows you to quickly view overall usage trends of your Synology NAS, create and manage tasks to analyze storage spaces, and generate detailed reports on volume usage.
    • You can select report types, create a schedule to generate periodic storage reports, and easily view previous reports that match the specified time or criteria.
  20. Storage Manager (for RS10613xs+, RS3413xs+, RS3614xs, RS3614RPxs, RS3614xs+ only)
    • You can now create volumes up to 200 TB large.
    • You can create RAID groups and RAID arrays. A RAID group for Multiple Volumes or iSCSI LUNs (Block-Level) that use RAID 5 or RAID 6 may contain multiple RAID arrays.
    • Synology Hybrid RAID is no longer supported.
  21. Log Center
    • Added IPv6 support for log sending and receiving.
    • Added supports for customized log formats.
  22. MyDS Center
    • Added a wizard to consolidate multiple MyDS accounts into one account for easy management and convenience. If you have multiple MyDS accounts, complete this wizard so you can continue enjoying our MyDS Center services.
    • You can easily monitor MyDS related services (DDNS/QuickConnect) at a glance.
    • You can modify account information and subscriptions directly in DSM.
  23. Text Editor
    • You can now use hotkeys to quickly perform common actions.
    • You can convert between Traditional and Simplified Chinese text.
  24. DSM Desktop
    • Push notifications can now be sent via Chrome and Safari.
    • You can change the main menu style to drop-down.
    • You can adjust the size of Desktop icons to be smaller.
  25. Misc
    • You can set global firewall rules for all network interfaces.
    • You can set default permissions for external drives.
    • You can define each FTP user’s root folder to be a folder other than their home folder.
    • You can filter Domain Users and Groups by Organizational Unit.
    • A command-line-based FTP client is built-in for automated tasks.
    • You can now customize the SSH port.
    • Python core is now built-in.
Caveats & Limitations
  1. Data Replicator has reached the end of its life span. You are encouraged to use Cloud Station to back up data on your PC or mobile device.
Quelle: https://www.synology.com/de-de/releaseNote/DS411
Grüße
TheTwist
raymond
10. Sep 2009
Mist zu spät: schon überlastet.
DKeppi
01. Apr 2011
raymond
10. Sep 2009
P4ddy
26. Okt 2009
Moin,
ich habe heute Morgen um halb sieben direkt das Update aufgespielt und danach das Komische verhalten gehabt, das MariaDb und die Photostation ein Update wollten, aber nicht unter der Kartei Aktualisierungen aufgtaucht sind. Beide hatten allerdings keine Option zum aktualisieren, sondern ließen sich nur deinstallieren.
Ich habe Dann MariaDB deinstalliert, aber in der Kartei "alle" war MariaDb gar nicht vorhanden, konnte es also nicht neu instalieren.
Hatte jemand dieses Phänomen noch?
Matthieu
03. Nov 2008
Puppetmaster
03. Feb 2012
Wow! DSM-Auto-Update ist in der Final nun enthalten!
Leute, ahnt ihr auch schon, was da auf uns zukommen wird hier ... ? :eek:
Matthieu
03. Nov 2008
Das Herunterladen der Firmware-Dateien zwecks Torrent gestaltet sich momentan etwas schwierig ... Außerdem hat Synology das md5-Verfahren umgestellt, sodass jede Datei nun eine eigene MD5-Datei hat (und nicht mehr alle Hashes in einer Datei wie bisher).
MfG Matthieu
blinddark
03. Jan 2013
Matthieu
03. Nov 2008
Welchen Server nutzt du? Ich habe den Vorgang jetzt abgebrochen - ich bekomme entweder sehr langsame Downloads oder gleich korrupte Dateien.
MfG Matthieu
EDIT: Hab gerade gesehen dass die Dateien auf usdl jetzt auch vorrätig sind. Der ist meist der schnellste.
blinddark
03. Jan 2013
raymond
10. Sep 2009
Update direkt in DSM funktioniert bei mir noch nicht :(
syntec
08. Apr 2009
Moin,
Testweise auf einer 112j erst die Pakete (u.a. Photostation, MariaDB, Download..) aktualisiert und dann manuell die neue Firmware, alles problemlos.
bigmag
25. Jan 2007
Hi
Ist das bei euch auch so, der High Availability Manager als fester Bestandteil der DSM 5.1 installiert wird und man ihn nicht deinstallieren kann ??
Sonnst alles Tip Top bis jetzt :eek:
Matthieu
03. Nov 2008
http://ukdl.synology.com/download/DSM/5.1/5004
Geschwindigkeit ist noch konstant. Wo finde ich die aktuellen packages? dann stelle ich die auch bereit.
usdl ist der Ordner leider noch leer. Dafür haben sie wohl ukdl neu gestartet. Vor etwa zwei Stunden hat der kaum noch geantwortet, geschweige denn Dateien ausgeliefert.
Das mit den Packages ist nicht ganz so einfach, weil jedes Paket einen eigenen Unterordner und eine eigene Versionsnummer hat:
http://ukdl.synology.com/download/spk/
MfG Matthieu
blinddark
03. Jan 2013
Schade... naja dsm liegt bereit.
Giri
14. Aug 2012
Cloud Station Client
Hallo zusammen
Hat jemand schon den neusten Cloud Station Client (Mac & Windows) finden können - offenbar geistert die Version 3.1-3317 rum ?
Der Mac client (3.1-3235) hat ja den unschönen Bug, das ein "cloud-ui" Symbol/Fenster offen bleibt.
DSM 5.1 und das Update des Cloud-Station servers auf dem NAS triggert offenbar keinen Client update, somit bin ich auf der Suche nach dem standalone Installer, damit ich den Client manuell auf den Mac's installieren kann.
*** Update ***
Der Client kann direkt via NAS / Cloud-Station heruntergeladen werden.
Mit der Version 3.1-3317 ist auch das lästige "cloud-ui" Fenster beim Mac client weg.
Vielen Dank
Daniel
raymond
10. Sep 2009
Matthieu
03. Nov 2008
raymond
10. Sep 2009
argh...immer noch kein Download direkt in DSM möglich. Durch das seeden und die Tatsache dass schon ein paar umgestiegen sind, muss es doch langsam mal möglich sein auch in DSM direkt das Update angeboten zu bekommen.
