Installation von Tiny Tiny RSS/Start-Stop-Skript
#!/bin/sh
# starts "Tiny Tiny RSS"ses update daemon
# put it into /usr/local/etc/rc.d/ with the suffix .sh
# chmod 755 on it
# Here, /var/services/web/ttrss/ must be changed to the directory that you installed Tiny Tiny RSS into
DM_CMD="/usr/bin/php /var/services/web/ttrss/update.php --daemon"
getPID ()
ps|grep "$DM_CMD"|grep -v grep|awk '{print $1}'
return $?
# If you need logging information, you can change LOGFILE to another file.
# It must be writable by the user nobody.
# If you need some sensible logging information, remove the parameter --quiet.
LOGFILE=/dev/null
start_daemon () {
su -m nobody -c "(trap '' SIGHUP && $DM_CMD --quiet >> $LOGFILE 2>&1) &" 2> /dev/null
return $?
reset_crond () {
ps |grep /usr/sbin/crond|grep -v grep|awk '{print $1}'|xargs kill -HUP
return $?
# It is very important that the tabs in the next line are preserved!
cronLine="* * * * * root "`realpath $0`" cron"
case $1 in
start)
start_daemon
stat=`getPID`
if [ -z "$stat" ]; then
echo "$cronLine" >> /etc/crontab
reset_crond
fi
stop)
PID=`getPID`
kill $PID
cron)
stat=`getPID`
start_daemon
fi
sed -i -e "\\%$cronLine% d" /etc/crontab
reset_crond
echo "Wrong argument. Usage: $0 start|stop"
esac
