Archiv:Synology Toolset
Version vom 18. August 2011, 17:49 Uhr von imported>Itari
Synology hat ab DSM3 einige eigen-entwickelte Tools dokumentiert.
/bin
ash - Kommandointerpreter/Almquist-Shell
busybox - BusyBox combines tiny versions of many common UNIX utilities into a single small executable. It provides minimalist replacements for most of the utilities you usually find in GNU coreutils, util-linux, etc. The utilities in BusyBox generally have fewer options than their full-featured GNU cousins; however, the options that are included provide the expected functionality and behave very much like their GNU counterparts.
cat [-u] [FILE]... - Concatenate FILEs and print them to stdout
  • -u Use unbuffered i/o (ignored)
catv [-etv] [FILE]... - Display nonprinting characters as ^x or M-x
  • -e End each line with $
  • -t Show tabs as ^I
  • -v Don't use ^x or M-x escapes
chgrp [-RhLHP]... GROUP FILE... - Change the group membership of each FILE to GROUP
  • -R Recurse
  • -h Affect symlinks instead of symlink targets
  • -L Traverse all symlinks to directories
  • -H Traverse symlinks on command line only
  • -P Don't traverse symlinks (default)
chmod [-R] MODE[,MODE]... FILE... - Each MODE is one or more of the letters ugoa, one of the symbols +-= and one or more of the letters rwxst
  • -R Recurse
chown [-RhLHP]... OWNER[<.|:>[GROUP]] FILE... - Change the owner and/or group of each FILE to OWNER and/or GROUP
  • -R Recurse
cp [OPTIONS] SOURCE DEST - Copy SOURCE to DEST, or multiple SOURCE(s) to DIRECTORY
  • -a Same as -dpR
  • -R,-r Recurse
  • -d,-P Preserve symlinks (default if -R)
  • -L Follow all symlinks
  • -H Follow symlinks on command line
  • -p Preserve file attributes if possible
  • -f Force overwrite
  • -i Prompt before overwrite
  • -l,-s Create (sym)links
date [OPTIONS] [+FMT] [TIME] - Display time (using +FMT), or set time
  • [-s,--set] TIME Set time to TIME<7li>
  • -u,--utc Work in UTC (don't convert to local time)
  • -R,--rfc-2822 Output RFC-2822 compliant date string
  • -I[SPEC] Output ISO-8601 compliant date string
  • SPEC='date' (default) for date only, 'hours', 'minutes', or 'seconds' for date and time to the indicated precision
  • -r,--reference FILE Display last modification time of FILE
  • -d,--date TIME Display TIME, not 'now'
  • -D FMT Use FMT for -d TIME conversion
Recognized TIME formats:
hh:mm[:ss]
[YYYY.]MM.DD-hh:mm[:ss]
YYYY-MM-DD hh:mm[:ss]
[[[[[YY]YY]MM]DD]hh]mm[.ss]
dd [if=FILE] [of=FILE] [ibs=N] [obs=N] [bs=N] [count=N] [skip=N] [seek=N] [conv=notrunc|noerror|sync|fsync] - Copy a file with converting and formatting
  • if=FILE Read from FILE instead of stdin
  • of=FILE Write to FILE instead of stdout
  • bs=N Read and write N bytes at a time
  • ibs=N Read N bytes at a time
  • obs=N Write N bytes at a time
  • count=N Copy only N input blocks
  • skip=N Skip N input blocks
  • seek=N Skip N output blocks
  • conv=notrunc Don't truncate output file
  • conv=noerror Continue after read errors
  • conv=sync Pad blocks with zeros
  • conv=fsync Physically write data out before finishing
Numbers may be suffixed by c (x1), w (x2), b (x512), kD (x1000), k (x1024), MD (x1000000), M (x1048576), GD (x1000000000) or G (x1073741824)
df [-Pkmh] [FILESYSTEM]... - Print filesystem usage statistics
  • -P POSIX output format
  • -k 1024-byte blocks (default)
  • -m 1M-byte blocks
  • -h Human readable (e.g. 1K 243M 2G)
dmesg dnsdomainname echo egrep false fgrep get_key_value grep gunzip gzip hostname ip ipcalc kill ln login ls mkdir mknod more mount mv netstat ntfs-3g ntfs-3g.probe pidof ping ping6 ps pwd rm rmdir run-parts sed sh sleep stat stty su sync synodd tar touch true umount uname usleep vi zcat
