Archiv:Synology Toolset
Synology hat ab DSM3 einige eigen-entwickelte Tools dokumentiert.
/bin
ash - Kommandointerpreter/Almquist-Shell
busybox - BusyBox combines tiny versions of many common UNIX utilities into a single small executable. It provides minimalist replacements for most of the utilities you usually find in GNU coreutils, util-linux, etc. The utilities in BusyBox generally have fewer options than their full-featured GNU cousins; however, the options that are included provide the expected functionality and behave very much like their GNU counterparts.
cat [-u] [FILE]... - Concatenate FILEs and print them to stdout
- -u Use unbuffered i/o (ignored)
catv [-etv] [FILE]... - Display nonprinting characters as ^x or M-x
- -e End each line with $
- -t Show tabs as ^I
- -v Don't use ^x or M-x escapes
chgrp [-RhLHP]... GROUP FILE... - Change the group membership of each FILE to GROUP
- -R Recurse
- -h Affect symlinks instead of symlink targets
- -L Traverse all symlinks to directories
- -H Traverse symlinks on command line only
- -P Don't traverse symlinks (default)
chmod [-R] MODE[,MODE]... FILE... - Each MODE is one or more of the letters ugoa, one of the symbols +-= and one or more of the letters rwxst
- -R Recurse
chown [-RhLHP]... OWNER[<.|:>[GROUP]] FILE... - Change the owner and/or group of each FILE to OWNER and/or GROUP
- -R Recurse
cp [OPTIONS] SOURCE DEST - Copy SOURCE to DEST, or multiple SOURCE(s) to DIRECTORY
- -a Same as -dpR
- -R,-r Recurse
- -d,-P Preserve symlinks (default if -R)
- -L Follow all symlinks
- -H Follow symlinks on command line
- -p Preserve file attributes if possible
- -f Force overwrite
- -i Prompt before overwrite
- -l,-s Create (sym)links
date [OPTIONS] [+FMT] [TIME] - Display time (using +FMT), or set time
- [-s,--set] TIME Set time to TIME<7li>
- -u,--utc Work in UTC (don't convert to local time)
- -R,--rfc-2822 Output RFC-2822 compliant date string
- -I[SPEC] Output ISO-8601 compliant date string
- SPEC='date' (default) for date only, 'hours', 'minutes', or 'seconds' for date and time to the indicated precision
- -r,--reference FILE Display last modification time of FILE
- -d,--date TIME Display TIME, not 'now'
- -D FMT Use FMT for -d TIME conversion
Recognized TIME formats:
hh:mm[:ss]
[YYYY.]MM.DD-hh:mm[:ss]
YYYY-MM-DD hh:mm[:ss]
[[[[[YY]YY]MM]DD]hh]mm[.ss]
dd [if=FILE] [of=FILE] [ibs=N] [obs=N] [bs=N] [count=N] [skip=N] [seek=N] [conv=notrunc|noerror|sync|fsync] - Copy a file with converting and formatting
- if=FILE Read from FILE instead of stdin
- of=FILE Write to FILE instead of stdout
- bs=N Read and write N bytes at a time
- ibs=N Read N bytes at a time
- obs=N Write N bytes at a time
- count=N Copy only N input blocks
- skip=N Skip N input blocks
- seek=N Skip N output blocks
- conv=notrunc Don't truncate output file
- conv=noerror Continue after read errors
- conv=sync Pad blocks with zeros
- conv=fsync Physically write data out before finishing
Numbers may be suffixed by c (x1), w (x2), b (x512), kD (x1000), k (x1024), MD (x1000000), M (x1048576), GD (x1000000000) or G (x1073741824)
df df [-Pkmh] [FILESYSTEM]... - Print filesystem usage statistics
- -P POSIX output format
- -k 1024-byte blocks (default)
- -m 1M-byte blocks
- -h Human readable (e.g. 1K 243M 2G)
dmesg
dnsdomainname
echo
egrep
false
fgrep
get_key_value
grep
gunzip
gzip
hostname
ip
ipcalc
kill
ln
login
ls
mkdir
mknod
more
mount
mv
netstat
ntfs-3g
ntfs-3g.probe
pidof
ping
ping6
ps
pwd
rm
rmdir
run-parts
sed
sh
sleep
stat
stty
su
sync
synodd
tar
touch
true
umount
uname
usleep
vi
zcat
