Archiv:Synology Toolset
Synology hat ab DSM3 einige eigen-entwickelten Tools dokumentiert.
/bin
ash - Kommandointerpreter/Almquist-Shell
busybox - BusyBox combines tiny versions of many common UNIX utilities into a single small executable. It provides minimalist replacements for most of the utilities you usually find in GNU coreutils, util-linux, etc. The utilities in BusyBox generally have fewer options than their full-featured GNU cousins; however, the options that are included provide the expected functionality and behave very much like their GNU counterparts.
cat [-u] [FILE]... - Concatenate FILEs and print them to stdout
- -u Use unbuffered i/o (ignored)
catv [-etv] [FILE]... - Display nonprinting characters as ^x or M-x
- -e End each line with $
- -t Show tabs as ^I
- -v Don't use ^x or M-x escapes
chgrp [-RhLHP]... GROUP FILE... - Change the group membership of each FILE to GROUP
- -R Recurse
- -h Affect symlinks instead of symlink targets
- -L Traverse all symlinks to directories
- -H Traverse symlinks on command line only
- -P Don't traverse symlinks (default)
chmod [-R] MODE[,MODE]... FILE... - Each MODE is one or more of the letters ugoa, one of the symbols +-= and one or more of the letters rwxst
- -R Recurse
chown [-RhLHP]... OWNER[<.|:>[GROUP]] FILE... - Change the owner and/or group of each FILE to OWNER and/or GROUP
- -R Recurse
cp [OPTIONS] SOURCE DEST -
- -a Same as -dpR
- -R,-r Recurse
- -d,-P Preserve symlinks (default if -R)
- -L Follow all symlinks
- -H Follow symlinks on command line
- -p Preserve file attributes if possible
- -f Force overwrite
- -i Prompt before overwrite
- -l,-s Create (sym)links
date dd df dmesg dnsdomainname echo egrep false fgrep get_key_value grep gunzip gzip hostname ip ipcalc kill ln login ls mkdir mknod more mount mv netstat ntfs-3g ntfs-3g.probe pidof ping ping6 ps pwd rm rmdir run-parts sed sh sleep stat stty su sync synodd tar touch true umount uname usleep vi zcat
