Synology Disk Station Manager 2.1-0803
DROPTABLE
02. Dez. 2008
Huhu
Seit eben ist die neue Firmware verfügbar ! :D
Achtung ! ... es ist eine BETA Version !
Genaueres findet Ihr hier ...
http://www.synology.com/enu/support/beta/Synology_all_DSM0803_2009.php
New Features
1. New DSM 2.1 Interface: The new Synology Disk Station Manager 2.1 introduces to you Windows-style login desktop. Only authorized applications are displayed after login. The newly added Quick Search Box allows "search while you type" for faster access to a setup page.
2. Enhanced Storage Management: RAID 5+Spare & JBOD volume type are supported. RAID 5+Spare volume further secures data safety and availability (supported on CS407, CS407e, DS408, DS508, RS407, RS408 and RS408-RP only); JBOD (Just a Bunch Of Disks) provides an alternative for users to concatenate multiple hard drives as a single volume without wasting any storage capacity.
3. You've Got Mail! Just 1-step installation of the stand-alone Mail Station package, your Synology NAS Server becomes a mail server that supports Outlook-style Web mail, SMTP, POP3 and IMAP. (supported on DS107+, DS207+, DS209+, CS407, DS408, RS407, RS408, RS408-RP, and DS508 only)
4. AJAX-based File Station 2: File Station 2 has a brand new interface that utilizes AJAX technology and brings you the familiar Windows experience with drag-n-drop and right-click actions. In addition, File Station 2 further introduces features including multiple files selection and upload(1) (up to 100 files), multiple files download, remote compressed files extraction and files/folders direct download URL.
5. AJAX-based Surveillance Station 2: The Surveillance Station 2 newly supports 59 IP cameras of renowned brands, including AXIS, ACTi, Vivotek, and SparkLAN. Audio streaming(2) is supported in live view, recording and playback (MPEG4 only). The auto-discovery feature helps you search the IP cameras within LAN to simplify IP camera setup.
6. Sub-folder Privileges Setting: With the elegant Linux-style privileges, authorized users are free to modify privileges of folders, sub-folders, and files with the help of File Station 2.
7. Enhanced User Management: "User Home" feature automatically creates a home folder and personal website address for each user; this greatly minimizes admin's effort to assign shared folder for each user. The application privilege setting allows the admin to flexibly determine applications (FTP services, File Station, Audio Station, Download Station and Surveillance Station) each user can access. In addition, the admin is now able to set up share folders privileges for each user.
8. Enhanced Audio Station: Upon proper applications privileges setting, non-admin users will be able to login Audio Station and enjoy the music in web streaming mode. Advanced privilege settings are available in Audio Station including allowing non-admin users to use USB mode and manage the playlists.
9. Enhanced Photo Station 3: The search function helps visitors find the photo/album more easily. Furthermore, other than the photo files, now you can choose to back up photo database via Local or Network Backup, including photo's extended information: titles, descriptions, and comments from visitors.
10. Enhanced Backup: The new backup wizard integrates Network Backup or Local Backup to simplify backup process. Other than Local Backup, Local Restore is now available; In addition, block level backup is supported in Network Backup. MySQL database backup is also supported now.
11. Enhanced eMule Download: The eMule download engine is upgraded to support files larger than 4GB.
12. Case-Sensitive File System: Case-sensitive file system is automatically supported after firmware upgrade to provide better Linux and Mac compatibility.
13. Network UPS: Now you can use a single UPS to protect multiple Synology NAS Servers within the LAN from power failure.
14. Dual-Printer Support: Synology NAS Servers now support up to 2 USB printers at the same time.
15. Linux Version Assistant: A Linux version Synology Assistant is now available to help you easily search Synology NAS Servers within the LAN environment.
16. 4 New Languages Support: Portuguese (Brazil), Portuguese (European), Turkish, and Hungarian management interfaces are now supported. It also takes effect on Synology Assistant, Synology Data Replicator 3, and Synology Download Redirector.
Danke für die Info!
Trolli
Die neuen Features sind schon cool, schade nur, das es die Mail Station nicht für die DS107 gibt, darauf hatte ich mich schon gefreut. Muß mir wohl überlegen ob ich ein "Hardware-Upgrade" mache :rolleyes:
Phil
was ist damit gemeint, bzw. wo kann man den mailserver finden?
Wenn Du dich für die Beta anmeldest, bekommst Du ja den Download-Link zugeschickt. Auf dem FTP-Server findest Du das Package für den Mailserver unter 'Packages'. Wird dann über das Paketmanagement im Disk Station Manager installiert...
Trolli
*grmpf*
danke....
habe ich vorhin beim dl nicht gesehen...
Hallo, funktioniert soweit alles ganz gut mit der DS-209+
Die neue Oberfläche ist jetzt auch viel besser.
Man sieht am Anfang nur den Login, ohne Audio-Station und so weiter. Somit sieht keiner was man alles offen hat.
Was mir auch gefällt:
-Alles als Benutzer verwendbar, nur DSM nicht, somit Kinderfreundlich.
-AudioStation als Benutzer verwendbar und Playlist auch editierbar (steht in der Beta-Beschreibung daß es nicht geht, geht aber).
-Suchfunktion in der Photostation funktioniert super
-Filemanager: Die Oberfläche ist jetzt stark verbessert worden. Ordner sliden auf, Ordner-Icons sind schöner,....
Einige Sachen sind mir aufgefallen:
-Im DSM steht immer noch 2.0, im Mainscreen steht aber 2.1
-In der Photostation muss man jeden Album-Ordner manuell einem Benutzer freigeben. Man kann zwar oben alle anwählen, aber es werden nur alle Ordner die gerade angezeigt werden angehackerlt. Hat man 16 Seiten Ordner wird das für jeden Benutzer mühsam. Neue Ordner muss man auch immer manuell neu freigeben. Irgendwie eine zähe Geschichte.
Geht das irgendwie, daß man einem Benutzer ohne Admin-Rechte alle Ordner und neuen Photostation-Ordner automatisch freigibt?
-Im Filemanager kann man als Benutzer nicht auf den Ordner music zugreifen, nicht mal öffnen, alles andere aber schon. Seltsam.
Funktionieren bei euch die Rechte der Benutzer so wie es soll (Schreiben, Löschen, Lesen?)
Hallo, so jetzt funktioniert es mit den Rechten.
Hat mich verwirrt, daß der admin auch in der Gruppe users ist.
Alle Benutzer & Admin sind in der Gruppe users und lassen sich aus users nicht entfernen.
Also:
Man muss die Standard-Gruppe users von RW auf RO umstellen und wenn nötig eine neue Gruppe mit RW-Rechten erstellen, dann gehts.
Obwohl admin=users wird es in den Privilegieneinstellungen für admin ignoriert wenn man nur Lesezugriff einstellt. Der admin bleibt weiterhin mit Vollzugriff ausgestattet.
Was passiert eigentlich wenn man den admin deaktiviert? Geht das überhaupt?
Sperrt man sich da nicht selbst aus?
Das scheint nur für bereits existierende Benutzer so zu sein (auch bei meinen Benutzern erscheint der "Bibliothek" Link).
Wenn ich aber einen neuen Benutzer erstelle, kann ich dem Rechte geben soviel ich will, der Link zur Bibliothek in der AudioStation erscheint nicht so wärs wahrscheinlich auch gedacht).
ich denke nicht dass das so gewollt ist.
Hallo, melde dich als admin in der Audiostation an und dann gehe auf Rechte. Da kannst du Userfreigaben einstellen.
Wie lange dauert es gewöhnlich bis es die FW in die Finale Version schafft? Ich kanns kaum abwarten. Leider kann ich nicht einfach eine Beta installieren, da man ja nie vor kleinen Fehlern gesichert ist, die alles lahm legen können und ich brauch meine DS fast 24/7.
Wen ich mich Recht erinnere, war es bei den letzten betas so 3-4Wochen bis zur final. Aber sicher weiss das wohl nur synology.
best regards
Bisher festgestellte Fehler (DS 207+)
will hier mal die bei mir aufgetauchten Fehler nach update der beta aufzählen.
1. Im DSM2.1 kann ich den iTunes Service nicht aktivieren (kann das Kästchen zwar aktivieren jedoch nach dem klicken auf OK verschwindet der Hacken wieder obwohl DSM sagt "Einstellungen übernommen"
2. Wenn ich die mailStation mit http://xxxxxxxxx.dyndns.org/mail/ aufrufen will erscheint die Fehlermeldung:
"DATABASE ERROR: CONNECTION FAILED!
Unable to connect to the database!
Please contact your server-administrator."
Bei der Ersteinrichtung hat jedoch alles funktioniert !
3. Beim aufrufen der PhotoStation mit http://xxxxxxxxxx.dyndns.org/photo/ erscheint Fehlermeldung:
"Warning: pg_connect() [function.pg-connect]: Unable to connect to PostgreSQL server: could not connect to server: No such file or directory Is the server running locally and accepting connections on Unix domain socket "/tmp/.s.PGSQL.5432"? in /usr/syno/synoman/phpsrc/photo/include/database.php on line 7
Failed to connect"
4. Beim streaming auf PS3 werden die Unterordner aus music, photo, video nicht mehr erkannt.
Bitte um Hilfe.
MfG
