Business Neue Version 3.1.0-24957
Adama
05. März 2013
Mir wird eine neue Active Backup Version angeboten:
 Version: 3.1.0-24957
(2025-10-16)
Compatibility and Installation
    Supports the following models (previously not supported in Active Backup for Business 3.0.0): DS416play and DS418play.
Important Note
    Supports automatically renaming existing items during file server restores when a type conflict occurs.
What's new
    Improved restore performance via Apple Migration Assistant.
    Supports selecting multiple virtual machines on non-hierarchical hypervisors.
    Supports Windows Volume Shadow Copy Service (VSS) for SMB file shares when backing up NetApp file servers.
Fixed Issues (General Issues)
    Fixed an issue where backups might fail when running on a network interface not managed by DSM.
    Fixed an issue where downloading a folder from the Restore Portal might fail due to a corrupted file.
    Fixed an issue where the backup time might incorrectly display.
    Fixed an issue where backup copies might fail to replicate properly and the status might be incorrect when joining an ActiveProtect site with a management server running APM 1.1 or later.
Fixed Issues (Mac)
    Fixed an issue where storage space on Mac might be used up because snapshots were not removed after a backup failure.
Fixed Issues (Virtual Machines)
    Fixed an issue where application-aware backups on Hyper-V might fail if a snapshot took too long.
    Fixed an issue where backups might fail if a VMware hypervisor password contained non-ASCII characters.
    Fixed an issue where pre-freeze or post-thaw scripts might fail if the virtual machine running Windows had a temporary path that contained spaces.
    Fixed an issue where Hyper-V virtual machine restores failed due to vSwitch name conflicts.
    Fixed an issue where automatic discovery might add unsupported virtual machine types to backup tasks.
    Fixed an issue where backups might not be verified if the number of disks exceeded eight.
    Fixed an issue where hypervisors used as restore destinations might still be deleted.
    Fixed an issue where virtual machine backups or restores might fail due to network instability.
Limitation
    Synology NAS models DS416play and DS418play can't join an ActiveProtect site.
Anmerkungen:
    This version is released in a staged rollout.
Bei der vorigen Version taucht jetzt dies auf:
Version: 3.1.0-24948
(2025-10-07)
This version was replaced by 3.1.0-24957 because the staged rollout of 3.1.0-24948 was paused to fix some issues.
https://www.synology.com/de-de/releaseNote/ActiveBackup?model=DS918+&os=DSM&version=7_x_series
Ich hab grad mal die History vergleichen, das scheinen die einzigen Unterschiede zu sein:
Important Note
Limitation
Reaktionen: DaveR
Danke 👍
Direkt installiert und danach wurde auch für den Clienten die 3.1.0 - 4957 (davor war es die 3.1.0 - 4948) als neue Version installiert. Dabei habe ich festgestellt, dass die Aktualisierung des Clienten bei ausgelasteter Internetverbindung (PC mit dem Clienten lastete gerade die Internetverbindung voll aus) mit Abgebrochen gestoppt wurde. Nachdem ich den laufenden Download des PC stoppte, ging auch die Aktualisierung aus dem ABFB heraus ohne Murren. Vmtl. braucht es eine bestimmte Bandbreite zwischen NAS und Synology-Server damit die Aktualisierung zum Clienten durchgeführt wird.
