habe versucht den iobroker zu installieren anhand dieser Anleitung.
https://forum.iobroker.net/topic/47...iobroker-in-docker-auf-synology-diskstation/2
Leider ist er über den Port nicht erreichbar und es hat den Anschein dass er die installations nicht komplett fertig gemacht hat.
2020-06-18 16:18:40 stdout host.buanet-iobroker1 check instance "system.adapter.info.0" for host "17b968cac726"
2020-06-18 16:18:40 stdout host.buanet-iobroker1 check instance "system.adapter.discovery.0" for host "17b968cac726"
2020-06-18 16:18:40 stdout host.buanet-iobroker1 check instance "system.adapter.admin.0" for host "17b968cac726"
2020-06-18 16:18:38 stdout
2020-06-18 16:18:38 stdout Starting ioBroker...
2020-06-18 16:18:38 stdout ------------------------------------------------------------
2020-06-18 16:18:38 stdout ----- Step 5 of 5: ioBroker startup -----
2020-06-18 16:18:33 stdout
2020-06-18 16:18:33 stdout For more information take a look at readme.md on Github!
2020-06-18 16:18:33 stdout Some adapters have special requirements/ settings which can be activated by the use of environment variables.
2020-06-18 16:18:33 stdout ------------------------------------------------------------
2020-06-18 16:18:33 stdout ----- Step 4 of 5: Applying special settings -----
2020-06-18 16:18:33 stdout Done.
2020-06-18 16:18:32 stdout No instances found for host "17b968cac726"!
2020-06-18 16:18:29 stdout Hostname needs to be updated to buanet-iobroker1...
2020-06-18 16:18:29 stdout Looks like this is a new and empty installation of ioBroker.
2020-06-18 16:18:29 stdout Done.
2020-06-18 16:18:29 stdout Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
2020-06-18 16:18:28 stdout (Re)Setting folder permissions (This might take a while! Please be patient!)...
2020-06-18 16:18:28 stdout ------------------------------------------------------------
2020-06-18 16:18:28 stdout ----- Step 3 of 5: Checking ioBroker installation -----
2020-06-18 16:18:28 stdout Existing installation of ioBroker detected in /opt/iobroker.
2020-06-18 16:18:28 stdout ----- Step 2 of 5: Detecting ioBroker installation -----
2020-06-18 16:18:28 stdout Done.
2020-06-18 16:18:28 stdout E: Paket vi kann nicht gefunden werden.
2020-06-18 16:18:26 stdout sudo: Hostname buanet-iobroker1 kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
2020-06-18 16:18:19 stdout The following packages will be installed: vi...
2020-06-18 16:18:19 stdout Installing additional packages is set by ENV.
2020-06-18 16:18:19 stdout ------------------------------------------------------------
2020-06-18 16:18:19 stdout ----- Step 1 of 5: Preparing container -----
2020-06-18 16:18:19 stdout ----- SETUID: 1000 -----
2020-06-18 16:18:19 stdout ----- SETGID: 1000 -----
2020-06-18 16:18:19 stdout ----- PACKAGES: vi -----
2020-06-18 16:18:19 stdout ----- ENV -----
2020-06-18 16:18:19 stdout ----- -----
2020-06-18 16:18:19 stdout ----- npm: 6.14.4 -----
2020-06-18 16:18:18 stdout ----- node: v10.21.0 -----
2020-06-18 16:18:18 stdout ----- image: v4.2.0 -----
2020-06-18 16:18:18 stdout ----- Versions -----
2020-06-18 16:18:18 stdout ----- -----
2020-06-18 16:18:18 stdout ----- arch: x86_64 -----
2020-06-18 16:18:18 stdout ----- System -----
2020-06-18 16:18:18 stdout ----- Debugging information -----
2020-06-18 16:18:18 stdout ------------------------------------------------------------
2020-06-18 16:18:18 stdout ----- Please be patient! -----
2020-06-18 16:18:18 stdout ----- Startupscript is now running. -----
2020-06-18 16:18:18 stdout ----- Welcome to your ioBroker-container! -----
2020-06-18 16:18:18 stdout --------------- 2020-06-18 18:18:18 ---------------
Über jede Hilfe wäre ich dankbar
