7.0.1-42218 Update 1
Jagnix
10. Okt. 2018
Neues Update, neues Glück:
Version: 7.0.1-42218 Update 1​
(2022-01-11)
Important Note
  1. This update has been recalled on January 1, since permission errors occur in the license files of packages.
  2. Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to manually update it. Only Synology NAS with DSM 7.0.1 installed can be updated to this version.
    • The update is not available in your region yet. The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
  3. This update will restart your Synology NAS.
Fixed Issues
  1. Fixed an issue where package logs weren't rotated after a switchover was performed on SA3200D.
  2. Fixed an issue where Synology Account might be signed out unexpectedly.
  3. Fixed an issue where the user interface response time might be longer when users ran user-defined scripts that included bind mounts.
  4. Fixed an issue where the time attribute of files on an exFAT-formatted external storage device was displayed incorrectly.
  5. Fixed an issue where there might be unexpected file permission changes in Surveillance Station due to multi-threaded file processing.
  6. Fixed an issue where SSD caches might stop functioning when there is insufficient system memory.
  7. Fixed an issue where mounting an encrypted shared folder on a Btrfs volume might fail.
  8. Fixed multiple security vulnerabilities. (Synology-SA-22:01)
Naja, lange war das Update 1 dann wohl nicht Verfügar, jedenfalls ist es jetzt nicht mehr da:
da ist derzeit nur die schon länger verfügbare DSM 7.0.1-42218 vorhanden, aber keine 7.0.1-42218-U1
offenbar hat Synology das U1 wieder zurückgezogen. Aus welchem Grund auch immer.
Die DSM 7.01.-42218 läuft schon länger bei mir auf der Test DS118.
Wurde zurückgezogen , jetzt ist Update 2 da. :)
Jetzt sind gerade wieder beide da -U1 und U2:
Jedenfalls vielen Dank Wadenbeißer für die Infos.
Und?
Hast schonmal auf den 1er draufgeklickt? Da kommst Du halt nicht weiter ...
Geht ganz normal 😎 gerade probiert
Komisch, wenn ich auf den 1er klicke, werde ich auf https://archive.synology.com/download umgeleitet .... :rolleyes:
Edit meint:
Ist ja cool .... Google Chrome schickt mich zum obigen Download-Link und der Browser Edge führt mich zum 1er Update :ROFLMAO:
Ein Schelm, wer Böses vermutet. :censored:
Update 2 seit gestern auf meinen Gerätschaften. Update war in paar Minuten und ohne Neustart durch.
DS920+ und DS416play wurden mit 7.0.1-42218 Update 2 aktualisiert.
Laufen soweit ohne Probleme.
Beide haben neu gestartet.
Beide Updates können heruntergeladen werden, selbstredend ist U2 zu verwenden. Dennoch ist es so gesehen wie gehabt bei DSM 6.
Ich habe bei mir sowohl auf der 218+ und der 720+ weniger RAM-Auslastung nach der Update Installation, bei gleichen Nutzungsbedingungen. Hat das noch jemand feststellen können?
Details:
RAM-Auslastung Vor Update / Nach Update:
DS720+ (18GB RAM): 45% / 41 % -> Reduktion um ca 720MB
DS218+ (10GB RAM): 33% / 20% -> Reduktion um ca 512MB
Das ist zwar nicht viel, aber für so ein kleines Update ohne Paket Updates schon beachtenswert.
